new to here, which truck to buy? 3 choices
Old Dec 27, 2008 | 09:41 PM
firemedic0135's Avatar
firemedic0135
Originally Posted by dodgeram07
1995 5.2 L, manual is nice,, but sound like a fishy deal....... 95 you cant get much of a tuner because the pcm is obd1. tuners are for obd2.. i would try to find a better one and get a manual if you can,,, or auto with new trans in.. that just me
yet another good point.
Old Dec 27, 2008 | 09:55 PM
98cherryram's Avatar
98cherryram
I personally think you are going to be best off with #3, I love my 5.2 manual, but the 01 is going to be in the best shape and a factory lift is going to be much better than that 6 inch lift on the 95, and as said before, a 2 inch spacer and an add a leaf you have 4 inches lift, whether you need it or not, really not sure, I like my 2.5 inches of lift on my rig, its seemed to do real nice for me, the only thing to look for on that 01 is cracks in the dash, those 01's seem to have problems with that that the other years dont...
Old Dec 27, 2008 | 10:04 PM
itsdaveonline's Avatar
itsdaveonline
Originally Posted by dhvaughan
check kbb private party for values. all those trucks are at the top, or over, what they are worth.
mileage is not too big of a concern. the engines can run 200k+ transmission is your biggest concern. +1 on having a transmission shop test it. even if your have to pay them $50. these trucks are notorious for needing very expensive rebuilds ($1500-2000), and that's often the reason they are for sale.
#2 may or may not have a cross threaded axle nut. if it was cross threaded, i doubt that you could ever get it tight, and the wheel would visible wobble. a basic inspection by wiggling the tire should confirm if there is an immediate problem. worst case is that you need a replacement outer stub shaft. not the end of the world, but a few hundred to pay someone to fix. maybe $100 for a stub shaft, assuming the $200 bearing is ok.
i would prefer the 01. less age. 5.9. better brakes. OBDII. offroad/4.10 gears. i would also much prefer a factory 2" lift over a 6" lift. just my opinion. i'd try real hard to get him down to $6000
Thank you that was really helpfull! So assuming the tranny and engine put out okay on truck two. id imagine paying 350$ worst case w/ install on that "stub shaft" issue. Emergency brake would be a nessisty, but also a cheap fix id imagine since its physical linkage with just a steel cable?? Correct? Maybe another 50$ fix....Then that just leaves us with the check engine light? perhaps an ignition issue? I guess the first step would be to check it out in person though and bring it to a shop and get it checked out and see if they cant pick up any codes and find the solution. Would your average dealership be able to test the transmission? Or would i need to goto a special tranny shop? And do you think i should get a compression test on truck 2 or 3? its only 95K & 100k.... Or should i get any truck i buy a compression test, regardless im going to get the truck i want to buy tested by a mechanic...
Im really sold on truck #2. But i think ill rule out truck #1 for the moment. Ill look into checking out both trucks 2 and 3 tomorrow. I really think i can get truck 2 on a good price maybe 4000$ish. I can save alot of money....
Kbb rates truck 2:
Excellent
$4,710
Good
$4,335
Fair
$3,860
More input appreciated! You guys have helped alot so far...
Old Dec 27, 2008 | 10:06 PM
itsdaveonline
Yeah thats the only thing im scared of that this truck might have a cracked dash. I know that you are basically screwed on that and dodge wont help out. I think i heard it was 1000$ for a new dash! Yikes!
Old Dec 27, 2008 | 10:28 PM
firemedic0135
dont go with the 1k dash.
there are covers that are very nice for 200bucks.
carpet ones for 40 bucks, while not the best looking option its still not worth discounting a trucks reliability.
Old Dec 27, 2008 | 10:36 PM
dhvaughan's Avatar
dhvaughan
again just my opinion. aftermarket items like lifts, headers, cams, etc, (which cost a lot), don't add any value to the truck. if anything, they decrease its value. a lot of people are very disappointed to find that out. they will spend $1000, 2000, 5000 or more dollars on a 95 truck, and when they go to sell it, its still a 95 truck and its only worth a standard amount, unless - they find that special buyer that really wants all those mods already done. and frankly - half the fun of all that stuff is putting it on. anyway, $4335 sounds about right.
a manual trans eliminates the biggest potential repair, the auto trans rebuild.
if you like #2, and want a professional inspection - call around to some repair shops, and request a 'buyers inspection'. expect to pay $50-100-200. dealer? maybe, i don't know. make sure they specifically check -
compression test (for blown head gasket, cracked heads, burned valves)
ALL front end parts, including wheel bearings, brakes, axle seals, ball joints, steering box, track bar, etc.
transmission, tcase, 4wd operation.
oil leaks,
rear end
body. any wrecks, repairs, non-stock paint lines, rust, paint condition.
having done all this, it is a '95 truck that's 13 years old, and its likely that it will have a lot of worn out parts. the point of the inspection is to avoid the abnormal lemon, that's about to cost you a big, expensive, and "unexpected" repair.
use the findings to negotiate the right price on the truck.
be prepared to walk away and write off the inspection cost.
common problems that are to be expected are
cracked dash, track bar, leaking front seals, blown plenum gasket. this is normal and things you have to sort of accept.
things to avoid, or at least negotiate in the price are cracked head, low compression, excessive oil leaks, auto trans problems, major wrecks, major rust.
Old Dec 27, 2008 | 10:58 PM
itsdaveonline
Well i would like to have the lift done already, thats why this vehicle sparks my interest. Plus a standard transmission is more fun to drive. I dont want to spend thousands of dollars on a lift or upgrading it myself. Actually i wouldent even bother with a lift if i bought a more expensive truck. Tires can get very pricy too!
But from what it sounds like, i should still get the tranny checked out regardless. It sounds like the standard is more durable than the auto...Ill see if i cant take a look at it and take some pictures of the truck. Underneath inside etc...
Thanks a lot!
Old Dec 27, 2008 | 11:19 PM
PurplDodge's Avatar
PurplDodge
I would definataly rule out truck #2.
Old Dec 27, 2008 | 11:36 PM
itsdaveonline
Looks like no-one likes the truck
I wouldent mind paying 4,200 for the truck and 500 or a little more in repairs.
But bluebook for the truck 3 shows:
Excellent
$8,380
Good
$7,930
Fair
$7,355
Its far below blue book, i dont know how much i can negotiate.... But we will see. Maybe there is something wrong with the truck...its really cheap...I just gota see!
The car im trying to sell:
Excellent
$6,745
Good
$6,270
Fair
$5,695
but who knows it could just work out.
Old Dec 28, 2008 | 01:18 AM
divetruck's Avatar
divetruck
If you dont want it breaking down every other month get a ford or chevy!
