put up some new fog lights
Old Dec 31, 2008 | 12:07 PM
  #21
iwhitne's Avatar
iwhitne
I'm guessing by using the quick spolicer on the head light relay you've damaged the wire.. therefore reducing the voltage running to the light... cut out the section were you tried to splice in the hellas an replace with new wire
Old Dec 31, 2008 | 12:25 PM
  #22
Viper37's Avatar
Viper37
Originally Posted by dodge15004x45.9
i thinking that im going to need a bigger altenator if i keep going.
Not if you go HID.
Old Dec 31, 2008 | 01:53 PM
  #23
dodge15004x45.9's Avatar
dodge15004x45.9
yep thats why i think i need a new cable and like a smart person who started this at like 11 at night i clip up close to where the lightbulb plugs into so im looking for a cable i called a local parts yard and the dumb female dog had no clue what i was talking about. when you say it plugs into the back of the lightbulb itself she was a waste of air!!!!!!
hey iwhitne what did u do with yr hella ff50 u still got the and where the fog or driving.
Old Dec 31, 2008 | 02:00 PM
  #24
Viper37's Avatar
Viper37
You are looking for a 9004 male Connector. I used one of those to activate my headlights, and another to activate my driving light relay box. I did that so I wouldn't molest any of my factory wiring.
The 9004 male connector will replace your factory one.
Old Jan 4, 2009 | 01:44 AM
  #25
iwhitne's Avatar
iwhitne
I ran postivie to battery from relay... ground to relay... ground to lights... hot wire to lights.... yellow wire to switch... green wire to switch from positive 12volt (not head light wire) and ground to switch (if you want it to light up when turned on)
