replacing rear window
Old Jan 2, 2009 | 11:58 AM
bonesbmx's Avatar
bonesbmx
Default replacing rear window
i have a 97 reg cab 1500 i need to replace the rear window (with the sliding glass)
has anyone done this it looks pretty straight forward but thought id cheack for some advice.
i figure ill pop out the old one cover the new one with window glue/sealer then put back in and seal again.
any thoughts?
Old Jan 2, 2009 | 12:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I did this on my 88 Dakota Express after some moron broke into it. I installed it using the rope trick and used no sealer. That was 15 years ago and it doesn't leak. But I'm sure when you get the new one it will have directions and recommendations on how to proceed with the install.
Old Jan 2, 2009 | 01:08 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
I tried to do one on a 91 Ford Ranger when it started to leak. Took me hours to do and it still leaked water. Wound up taking it to an autoglass place and had them do it for a very reasonable amount of time and money with good results. From then on my motto is: "I don't do windows."
Old Jan 2, 2009 | 02:19 PM
lastrights's Avatar
lastrights
i want the back window like tundras , where they go down like a reg window, that would be badass
Old Jan 3, 2009 | 08:52 AM
bonesbmx's Avatar
bonesbmx
im still undecided as to weather or not im going to try this. what is the rope trick? im using a window from the scrap yard got a good deal came tinted
Old Jan 3, 2009 | 09:06 AM
zman17's Avatar
zman17
You get a long enough piece to go all the way around the gasket and some extra both ends.You put the rope down in the gasket slot leaving about a foot hanging out both ends of rope. With some one outside to hold the window and push it in to seat the gasket as you pull the rope out from inside.
