Headlight Conversion 98 Ram to Ram Sport
Old Feb 16, 2005 | 09:43 PM
ljpierce_ely's Avatar
ljpierce_ely
Default Headlight Conversion 98 Ram to Ram Sport
Ok, being that I'm new to the forum, forgive me if I'm beating an old and dead horse. I recently purchased a set of Clear headlights designed for a 99-01 Ram Sport, and put them on my 98 Ram. I already had them on and performed all the sheet metal work required to install and wasted an entire day trying to figure out how to wire them up.
My problem is converting my dual 9004 lamps to use the new Sport Quad lamp setup (two 9004 and two 9007). Does anyone have a schematic and instructions to perform this conversion?? I didn't know, until last night, that the 99 Rams had a switched ground system that the 98 doesn't have, and that the 9007 bulbs are apparently wired differently as well.
I already re-installed the original lamps and headlight units until I can get the electrical issues resolved. Help!
Old Feb 17, 2005 | 01:41 PM
steve05ram360's Avatar
steve05ram360
Default RE: Headlight Conversion 98 Ram to Ram Sport
I went through the same problem... I bought from this group buy
http://www.pavementsucks.com/forums/...hp?topic=46547
and had issues with the wiring. What I do know is that the 9007 bulbs are wired differently and the ground is in the middle of the contacts on the bulb, the 9004 has the ground on one of the ends.
you will have to modify the housing to make it work with one of the bulbs, I forget which. the housing in the group buy used one of each of the 9007/4 bulbs so in order to use the 7's, a mod needed to be done.
read the thread and see if it helps... i ended up using a meter to figure out how the wiring needed to be. Now it's all good.
[IMG]local://upfiles/1508/D27C6428A28B466CB06705DAA1C66D66.jpg[/IMG]
Old Feb 18, 2005 | 02:08 PM
ljpierce_ely
The housing(s) that I purchased are already fitted for a 9004 and a 9007, so no mods are needed in that regard. The only thing I had to do was cut out some sheet metal to allow the second headlamp connector and twist holder to clear the area behind the headlight.
So, the 9007 has the ground in the center, not to the one side as the 9004 does. That helps a bit. I'll check the bulbs out and see what I come up with.
Anyone have a schematic to wire these to avoid causing the headlight switch to burn out?
Old Feb 18, 2005 | 02:18 PM
steve05ram360
here you go...
[IMG]local://upfiles/1508/4AAB1A1D1A4C40D9879A0A371EA09EAA.gif[/IMG]
Old Feb 18, 2005 | 02:20 PM
steve05ram360
did you get the wiring harness for the quad setup? I used the info on the Pavementsucks link. most of it worked but I ended up having to re-wire part of it because when I turned on my hi-beams, the lights would go dim...
Old Feb 18, 2005 | 02:42 PM
ljpierce_ely
Mucho thanks for the wiring diagram. That helps in the greatest amount. No, I didn't get any sort of wiring from anyone or anywhere. Mainly because I didn't think a wiring setup existed for the type of conversion I am attempting and I wasn't aware of the difference in wiring from the 98 Ram to the 99 Ram Sport.
Again, thanks a heap for the diagram!! I'll check out the Pavementsucks link too.
Old Feb 18, 2005 | 02:48 PM
steve05ram360
there was a wiring harness that you could get from that PS group buy that would simplify your install a bunch, check into it...
Old Feb 18, 2005 | 02:55 PM
ljpierce_ely
Just got back from looking at that link. Problem was, for some reason, not many of the pics loaded onto my computer (if it isn't one problem, its another!!<bg&gt Anyway, I'd definately be interested in picking up the wiring harness. I'll look into this in the next couple of hours.
Old Feb 18, 2005 | 03:06 PM
steve05ram360
I have that whole thread saved on my hard drive here at work, if you want a copy (2 files) I can e-mail them to you... pm me with your e-mail address if you want them.
