Need Help, Seized motor removal
Old Jan 3, 2009 | 04:20 PM
jsalansing's Avatar
jsalansing
Default Need Help, Seized motor removal
Hey everyone, I have a 97 Ram 1500 with a 318 and auto trans. The motor is seized and needs to be removed. My question is how do you get the torque converter bolts out when you can not turn the engine to access all of them ??
Thanks for any input,
Joe....
Old Jan 3, 2009 | 04:26 PM
MonteC's Avatar
MonteC
Just pull the transmission out. It will leave the TC on the flywheel. Then you should be able to access the TC bolts that way.
Old Jan 3, 2009 | 04:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Or leave the tranny there and pull the motor, Carefully of course.
Old Jan 3, 2009 | 09:56 PM
aim4squirrels's Avatar
aim4squirrels
Did you try the old trick of pouring Tranny fluid into the cylinders and letting it soak overnight to unseize the engine?
Sometime it work, sometime it no work.
Old Jan 3, 2009 | 11:04 PM
MonteC's Avatar
MonteC
Im so used to pulling transmissions, It just seems easier that way. LOL!
