Fuel seepage
Fuel seepage
This one is a new one to me. After driving my 1996 2500 v10 ram around a half hour or so, when I stop there is fuel spitting from around the top ring area of the fuel pump. I then release the pressure from the tank by loosening the gas cap and venting it. The fuel seems to stop seeping out when the pressure is off, but what could the issue be here? Could this be a evap issue or has anyone else had this same problem before? Thanks
That is very strange. How full is that tank? I've never had a problem with pressure build up like that even when going from 5000 to 12000 feet. Is it coming out from around the ring or from the top? If around the ring, then maybe just the seal but if out the top, there's a roll over valve up there and maybe it is leaking.
