Rear end is toast what should I do?
Old Jan 8, 2009 | 08:06 AM
dnfd737's Avatar
dnfd737
Default Rear end is toast what should I do?
So I had thim humming noise when I let off the gas I thought it would be just the pinion bearing but it looks like everything is bad, broken tooth on the ring gear clutch material from the lsd and metal shavings all over the place. The shop says $1200 to fix it but suggested a junk yard rearend might be better money wise. The rear end swap would be roughly $600 to $800.
Question is what should I do? Would a 4wd rear end be better than a 2wd rear end? I dont really care about the lsd since I have 2wd now and the most I do is haul a load of trash to the dump once in a while and pull my boat for maybe 1500 lbs about 5 miles to the lake.
Thanks for your input.
Old Jan 8, 2009 | 08:46 AM
Silver_Dodge's Avatar
Silver_Dodge
The rear from a 2wd and a 4wd were the same for 1500's - both 9.25's.
Old Jan 8, 2009 | 10:47 AM
dnfd737's Avatar
dnfd737
Well that makes things easy, Would you go junk yard or rebuild though?
Old Jan 8, 2009 | 01:23 PM
Silver_Dodge
If it were me, i'd probably just go junk yard.
Old Jan 8, 2009 | 01:26 PM
EricCartman's Avatar
EricCartman
I'm a cheapskate... so I would go with whatever was cheaper. However, if you were ever thinking about re-gearing, I would go with a rebuild.
Good luck,
Cartman
Old Jan 8, 2009 | 05:08 PM
jasonw's Avatar
jasonw
Site Moderator
I'd see if I could find the rear end out of a Off Road model. 4.10 gears baby.
Old Jan 8, 2009 | 05:38 PM
dnfd737's Avatar
dnfd737
4.10 gears????? I'm getting 20mpg now with my 3.55 I was kinda thinking 3.21 to get more mpg.
Do I need to change anything or reprogram the computer if I change to a diffrent gear?
Old Jan 8, 2009 | 11:04 PM
dhvaughan's Avatar
dhvaughan
no. the speed sensor reads the tone ring at the top of the pumpkin. its independent of gear ratio, and dependent only on tire size. your truck will be programmed for the stock tire size listed on the door jamb sticker.
Old Feb 5, 2009 | 04:56 PM
neattouch648's Avatar
neattouch648
mine did a similar thing. I went to my junkyard and he wanted 500 for a 2000 rear end, i ended up putting a new rear end from a 1996 for only 200 and it works out well. reused the yoke off of my original and everything (except the hand brake) works
Old Feb 5, 2009 | 05:25 PM
98cherryram's Avatar
98cherryram
Mine did it back in early october I think, I dont know how many people on the forum remember when I went through that ordeal. But it cost me $550 to get a rear end with only 40k miles on it, the first one I paid for had 80k on it but it went bad the night I got it swapped in, so the junkyard gave me the other one to replace the one that went bad. I did the swap myself, its not a real hard one except getting the e-brake set back up, but the only reason why that was tough on mine is because I have a 2 door with a back seat and the one they got me was from a 2 door without so the cables werent long enough, if you get one off the same cab and bed as yours you shouldnt have any problem reconnecting the e-brake.
