4WD Indicator
Old Jan 8, 2009 | 11:35 AM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Default 4WD Indicator
Do you guys know what causes the 4WD light not to come on when I have 4WD engaged? Does it have something to do with a bad sensor, or a dead bulb in the gauge cluster?
Old Jan 8, 2009 | 11:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be the bulb, or the switch on the CAD, or the connection or wire itself. Maybe the trans shop pulled it off or some thing by accident. Maybe you should go there and tell them it was working before you brought it there, and get your pan back at the same time.
Old Jan 8, 2009 | 01:37 PM
firemedic0135's Avatar
firemedic0135
Its prolly not thebulb.Tht bulb is one of the LED's you cannot replace.
There is a harness on the CAD with two black wires going to it.
Mine was ripped up right there.
Old Jan 8, 2009 | 02:18 PM
ophidia's Avatar
ophidia
+1 on the wiring or sensor itself.
Old Jan 8, 2009 | 11:18 PM
dhvaughan's Avatar
dhvaughan
wiring. not bulb.
start with the electrical connector. clean out the mud. spray it out with wd40. sometimes that fixes it.
if you jumper the pins in the electrical connector, the dash light should come on. this tests the wires and bulbs.
you can test the light switch on the end of the cad. when in 2wd the switch is open. when in 4wd the switch should be closed. if the switch is bad you can replace it from autozone, etc for about $15-20.
Old Jan 12, 2009 | 11:58 PM
blueram1500's Avatar
blueram1500
I had the same problem it ended up being my 4 wheel drive acuator was bad and not locking the front hub so the 4 wheel drive didnt work and the light wouldnt come on. Once i replace that acuator for the four wheel drive the light came on.
Old Jan 13, 2009 | 12:03 AM
dodge15004x45.9's Avatar
dodge15004x45.9
wheres whats his name going posi lock they sound like they are worth it.
