whistle sound
Old Jan 10, 2009 | 07:44 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Unhappy whistle sound
When I drive I noticed that my truck has begun to whistle/high pitched wine to the point where it hurts yr ears. Its only when i step on the gas and i dont mean floor it. As soon as i left off it stops. I have a k&n cold air intake on the truck do you think that might be my problem? and dose anyone know how wide 1500 leave springs are i want to get a lift and the kit says for 2.5" wide rear leaf spring.
Old Jan 10, 2009 | 10:59 PM
dhvaughan's Avatar
dhvaughan
rear leafs are 2.5 if you have a tape measure it ought to be pretty easy to check.
air whistle is an air leak around your air filter or intake, or possibly a vacuum line, or IAC, or TB gasket..
Old Jan 10, 2009 | 11:05 PM
dodge15004x45.9
im new to car lingo was an IAC and TB is timing belt?
Old Jan 10, 2009 | 11:08 PM
helms's Avatar
helms
IAC = Idle Air Control
TB = Throttle Body
Old Jan 10, 2009 | 11:14 PM
txredneckmedic's Avatar
txredneckmedic
Sounds like the air leak i have on mine when i loose my ac to the floor vents
Old Jan 11, 2009 | 09:22 AM
aim4squirrels's Avatar
aim4squirrels
Check the little rubber tube that goes to the TB right next to the MAP sensor. Mine was cracked due to heat and I couldn't find the whistle for the longest time.
Old Jan 11, 2009 | 01:17 PM
dodge15004x45.9
location of the map sensor
Old Jan 11, 2009 | 02:32 PM
aim4squirrels
Front of Throttle Body just under air hat. You'll see a long plastic tube covered in wiring convolute going straight into it, at the end is a rubber nipple. hehe.
Old Jan 11, 2009 | 03:28 PM
dodge15004x45.9
i checked my k&n its tight. The rubber tubes looked ok but its cold here so I wasnt going to spend to long out there its 20 here. I will look close tomorrow.
Old Jan 11, 2009 | 09:19 PM
aim4squirrels
one other thing. have you replaced the TB gasket recently? mine was a little misaligned and it whistled a bunch from interrupting the air flow to the intake.
