Gauge Pod
Old Jan 12, 2009 | 12:00 AM
PurplDodge's Avatar
PurplDodge
Default Gauge Pod
Does anybody have this gauge pod?
http://www.genosgarage.com/prodinfo....er=GM-DG-15002
Old Jan 12, 2009 | 01:32 AM
BlueBeast2's Avatar
BlueBeast2
I'm gonna get one of the A piller ones. The 2 pod full piller jobber
Old Jan 12, 2009 | 02:06 AM
helms's Avatar
helms
this is what i have, bought it two years ago. when i first got it i was a little dissapointed with the quality and the fact that i had to cut a hole in the original one where the speaker mounted, and the fact that the autometer one mounts on top of the original with cheap little plastic push tabs. its a little tight to get into place due to the extra girth and wires, but iv only had to remove it once for a faulty trans temp guage, other than that no complaints, its served me well.
Old Jan 12, 2009 | 06:35 AM
PurplDodge's Avatar
PurplDodge
They do ake ones for the speaker hole.
Old Jan 12, 2009 | 08:40 AM
xskylinedx's Avatar
xskylinedx
I purchased a dual pillar pod and instead of using those push tabs I glued it
together and clamped it with duct tape until dry. I would recommend high
strength glue that is designed for plastic.
Old Jan 12, 2009 | 10:08 AM
hometheaterman's Avatar
hometheaterman
I read something once saying the hole was in the wrong spot or something. I can't remember the link to thread but it was a guy trying to install one and the hole for the speaker didn't match up with the speaker so he had to cut some.
Old Jan 12, 2009 | 12:10 PM
helms's Avatar
helms
the speaker hole sticks out of the pillar on the stock one and the autometer pod requires a flat (no speaker) pillar to mount on, so you have to shave the protrusion off, or find a non speaker pillar. The speaker holes are in different places because the stock position is right between the two guages, so they move it toward the outside and down a bit, it still works fine though
Old Jan 12, 2009 | 05:13 PM
PurplDodge's Avatar
PurplDodge
Old Jan 12, 2009 | 05:17 PM
BlueBeast2's Avatar
BlueBeast2
i dont have a speaker. Do they all mount to the stock plastic? I thought the full size ones would totally replace the stock plastic
Old Jan 12, 2009 | 05:22 PM
PurplDodge's Avatar
PurplDodge
http://www.genosgarage.com/prodinfo....er=GM-DG-17202
