cylinder heads...
Old Jan 12, 2009 | 09:42 PM
helms's Avatar
helms
im sure this has been dicussed, but since we're on the topic, whats a tried and true aftermarket head for the magnum 5.9? has anyone had problems using aluminum on a DD?
Old Jan 12, 2009 | 09:55 PM
aim4squirrels's Avatar
aim4squirrels
There's RT heads, EQ heads, Edelbrock aluminum heads, and hughesengines.com makes a stock replacement HD head that flows better than stock. You can get a set of the hughes heads for under $400 and build them up if you know how.
Old Jan 12, 2009 | 11:27 PM
helms's Avatar
helms
well the hughes heads are under $400... each, but their bare, you still need valves (lapped), springs, retainers and keepers, but its still not a bad deal. The 2.02 with swirl polish are just over $1000 w/o springs keepers and retainers and they flow better than the Edelbrocks.
Old Jan 13, 2009 | 04:36 AM
talon6's Avatar
talon6
which ones are you talking about? i know nothing about heads. what kind of gains can you expect from the heads you are talking about? can you get some that are just bolt and go? already loaded with everything?
link me to those 1000$ heads. maybe something i might be interested in. thanks.
Old Jan 13, 2009 | 06:47 AM
froesen's Avatar
froesen
DH, your years are slightly off....92+ 318's are magnum, 93+ 360's are magnum. (possibly not in all applications, eg. van's and heavy duty's, but for regular pickups).
Old Jan 13, 2009 | 07:30 AM
dhvaughan's Avatar
dhvaughan
oops.
Old Jan 13, 2009 | 10:07 AM
talon6's Avatar
talon6
is this the heads you are talking about?
http://cgi.ebay.com/ebaymotors/NEW-E...Q5fAccessories
Old Jan 13, 2009 | 11:52 AM
steve05ram360's Avatar
steve05ram360
Those dont look like the Hughes heads do they? the CC has a different shape than the standard mag heads IIRC.
Old Jan 13, 2009 | 12:55 PM
deeznutts's Avatar
deeznutts
those are the same heads ive purchased..alot of meat to them..more so than r/t,s and allow for a good,,good bit of p.ping...
Old Jan 13, 2009 | 01:40 PM
talon6's Avatar
talon6
whats p.ping? port and polishing?....... do you have them installed? if so,how are they? would i gain much without changing the cam? gonna be supercharging at tax time if that makes any difference.
