cylinder heads...
Old Jan 12, 2009 | 02:21 PM
dmcpher's Avatar
dmcpher
Default cylinder heads...
i posted this earlier, but couldn't find
does anyone know if the 5.9 mangum heads are different then standard heads?
Old Jan 12, 2009 | 02:38 PM
MidKnight95's Avatar
MidKnight95
what do you mean by 'standard' heads
Gary-L's Avatar
Gary-L
Veteran: Navy
5.2L and 5.9L Dodge trucks use the same heads.
Old Jan 12, 2009 | 02:43 PM
dakotas ram's Avatar
dakotas ram
if by standard you mean non-magnum, then yes they are different....i believe they will bolt to the block but the intake holes are different
Old Jan 12, 2009 | 02:53 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
It just occurred to me that maybe he's wondering if heads from a truck with an automatic transmission will fit the engine of a truck with a standard transmission.
Old Jan 12, 2009 | 04:41 PM
deeznutts's Avatar
deeznutts
only difference in the magnum head series was the r/t heads..some had bigger valves..atleast to my knowledge
Old Jan 12, 2009 | 05:05 PM
dmcpher's Avatar
dmcpher
yes...
i meant standard as in regular old 5.9l 360, not standard trans. sorry, this is my first mopar
Old Jan 12, 2009 | 07:49 PM
devramstuff's Avatar
devramstuff
LA heads are fed oil through galleries
Magnum heads are fed oil through the lifters and push rods
LA intake bolts are go in parallel to the machined surface
Magnum intake bolts go in straight up and down(about 45 degrees to machined surface)
Magnum heads can be adapted to an LA block, not sure about the other way around, wouldn't want too anyways
Magnum heads are better for performance from what I hear, not sure why though.
Old Jan 12, 2009 | 08:03 PM
dhvaughan's Avatar
dhvaughan
good info ^.
just a little more explanation.
pre 94 was the LA 318/360. idk what LA stands for.
94+ was the Magnum 318/360 with the different heads.
Old Jan 12, 2009 | 09:22 PM
aim4squirrels's Avatar
aim4squirrels
Magnum heads have a higher flow (even higher than most of the LA aftermarket heads) and they have the ability to accept a 1.7 ratio rocker. The LA heads couldn't take more than a 1.6 rocker, stock was 1.5.
For an in depth look at the differences between LA and Magnum engines, read this article.
