Need valve help "floating valve"(?)
Old Jan 14, 2009 | 02:06 PM
  #21
aim4squirrels's Avatar
aim4squirrels
IDK the exact spring tension/rate is. I'd just buy them from the dealer to be sure.
Keep in mind that the TSB for wire routing was also written by a Chrysler Tech. And was written specifically for our vehicles as it was a known repeatable problem. Cold/hot ignition has very little to do with the spark jump. Its the location of those posts on the distributor and the order in which they fire that causes the issues.
Old Jan 14, 2009 | 03:54 PM
  #22
mcss8541's Avatar
mcss8541
Keep in mind that the FSM for wire routing was also written by a Chrysler Tech. And was written specifically for our vehicles as it was a known repeatable problem. Cold/hot ignition has very little to do with the spark jump. Its the location of those posts on the distributor and the order in which they fire that causes the issues.
really i didn't know that about the spk plg wires.
Old Jan 14, 2009 | 09:48 PM
  #23
aim4squirrels
sorry I had to edit, it was a Technical Service Bulletin on wire routing, not the Field Service Manual.
Old Jan 15, 2009 | 08:22 AM
  #24
mcss8541's Avatar
mcss8541
no worries Aim
Old Jan 15, 2009 | 08:23 AM
  #25
mcss8541's Avatar
mcss8541
Originally Posted by lv360ram
When you asked the 30+ year Chrysler professional expert mechanic how to fix the valve float - What did he say?
Hey Iv360 how much for your 50mm TB? How did you fab you dual snorkle intake?
Old Jan 15, 2009 | 09:18 AM
  #26
draftingmonkey's Avatar
draftingmonkey
Originally Posted by mcss8541
Haven't been racing although I did accelerate heavy to merge onto highway and the truck started bucking like a rev limiter was kicking in.
I know this doesn't help with your possible valve issue, but I used to have the same acceleration problem. Felt like a rev limiter kicking. Replaced the coil with an Accel coil (most folks seem to like MSD) and the problem went away and since then the truck will run right on up without a falter. Guess the factory coil was not quite up to the job. BTW replaced the coil months after replacing the cap, rotor, plugs (used Champion Truck plugs) and plug wires purchased from Napa.
Old Jan 15, 2009 | 09:45 AM
  #27
mcss8541's Avatar
mcss8541
Well when I did the wires change the coil wire was corroded where it snaps onto the coil and it is the original coil. I was looking at the Accel but I have a question; does my truck need the wiring adapter they talk about or is it the later models?
Old Jan 15, 2009 | 10:50 PM
  #28
draftingmonkey
Not sure about the adapter. I had to get the adapter cable for my '01 (Feb '00 build month). If you don't get an answer by Saturday, I will try to remember to take a look, and some pics, of the coil and adapter plug ends for comparison.
Old Jan 16, 2009 | 09:06 AM
  #29
mcss8541's Avatar
mcss8541
thank you sir i really appreciate it.
Old Jan 16, 2009 | 09:08 AM
  #30
mcss8541's Avatar
mcss8541
hey AIm my CEL went off by itself earlier this week after the 3rd double dose of fuel injector cleaner. as of this posting it still has not come back on. this has happened before where it will run "right" for about a few months then the miss will come back and trigger the cycl 5 misfire CEL. We'll see.
