Somethings loose???
Old Jan 15, 2009 | 02:51 PM
encorejc35's Avatar
encorejc35
Default Somethings loose???
alight, everytime i hit a bump or when im in 4 wheel drive, it feels like something is loose on the front drivers side(suspension), ive had the bearings checked and the ball joints and nothings loose or worn, i dont know what else it could be? maybe worn shocks???, any help would be apreciated
Old Jan 15, 2009 | 02:57 PM
dhvaughan's Avatar
dhvaughan
is it thumping under the feet of the driver or passenger ? if so, its the lower shock bolts not tightened up to their shoulder straining, feet braced on something, gut wrenching 100 pounds of torque.
ball joints,tie rods, track bar can all move around.
i don't quite get the connection to 4wd. that brings in drive line stuff.
Old Jan 15, 2009 | 03:35 PM
dblj16380's Avatar
dblj16380
I'm just throwing this out there but what about a front drive shaft u-joint? That would certainly thump a lot when you in 4 wheel and when your not, it is still spinning anyways.
Old Jan 15, 2009 | 04:22 PM
98BlueSport's Avatar
98BlueSport
I feel the samething. If i understand you correctly its like right under your left foot when driving. I looked under mytruck and the only thing there where the torsion bar connects to the frame. I've always wondered about it, but nver really gave it any thought about what is really going on down there
Old Jan 15, 2009 | 04:35 PM
dblj16380's Avatar
dblj16380
My best advice would be to just crawl under there one day and start moving things around a bit and figure out what stuff under there has any play in them. Even if it is not what is directly causing your rattle, it is still probably something that needs to be replaced.
Your front driveshaft u-joint should be in pretty much the exact spot described.
