Plenum Question
Old Jan 16, 2009 | 01:34 PM
txredneckmedic's Avatar
txredneckmedic
Default Plenum Question
Well I am quickly getting parts in to fix my truck....but heres my question. Talked to my mechanic earlier and he said he was just gonna swap out my old intake with the new one. How can i check the plenum gasket on the new one to make sure its ok and how much do them gaskets run?
Old Jan 16, 2009 | 01:48 PM
dhvaughan's Avatar
dhvaughan
need more info on what the 'new' intake is. if its an M1/airgap thing, then its cast as a single piece and doesn't have a plenum plate/gasket. however if its stock, then its a 2 piece intake and you have to bolt on the bottom plate, and the aluminum plate is the best long term fix.
the hughes plate kit with intake bolts is about $150.
see pics here to better describe it.
https://dodgeforum.com/forum/2nd-gen...ater-pump.html
Old Jan 16, 2009 | 05:18 PM
hometheaterman's Avatar
hometheaterman
Yep if it's stock get either that Hughes kit or the APS one.
Old Jan 16, 2009 | 07:23 PM
txredneckmedic
OK....im not looking to drop another $150 on this project right now....can i just go to napa and order a stocker?
Old Jan 16, 2009 | 07:54 PM
aim4squirrels's Avatar
aim4squirrels
the whole gasket set is a little over $30.
you'll need the actual plenum gasket and the 4 intake gaskets that rest on the engine/heads that the intake sits on. Get the felpro set if you have a choice in it.
Old Jan 16, 2009 | 08:04 PM
dhvaughan's Avatar
dhvaughan
$27 at rockauto for the felpro gasket.
http://info.rockauto.com/Fel-Pro/Det...5392-1_TOP.jpg
http://www.rockauto.com/catalog/x,ca...,parttype,5424
Old Jan 16, 2009 | 08:38 PM
txredneckmedic
http://www.napaonline.com/MasterPage...num+Gasket+Set
Thats what i need right.
