95 Dodge 1500 5.9L bucking at highway speeds
Old Jan 17, 2009 | 06:28 PM
st.joe68's Avatar
st.joe68
Default 95 Dodge 1500 5.9L bucking at highway speeds
I have a dodge that I've been having problems with. When cruising on the highway holding a constant speed the truck will start bucking or shuddering. To come out of it I can either release or depress the gas. This seems to typically happen when the truck has no real load on the engine. I can tow with the truck and it does good, probably because the throttle is always moving - although I have had it start bucking while towing. I have trouble code 32 and 37, 32 is due to removing the egr valve because I am to cheap to buy a new one. Don't know what the 37 is though - help please
Old Jan 17, 2009 | 08:47 PM
WaynesWorld's Avatar
WaynesWorld
search for plenum gasket leak test
Old Jan 17, 2009 | 11:24 PM
JackJ's Avatar
JackJ
How would that make the truck jump and shudder, I am having a similar problem. No CEL though.
Old Jan 17, 2009 | 11:30 PM
Mudbone25's Avatar
Mudbone25
Could be your MAP or TPS.
Old Jan 17, 2009 | 11:42 PM
st.joe68's Avatar
st.joe68
Default tests done
checked the TPS voltage it was good, checked the MAP it was good, I didn't see any oil nor am I losing any oil to the plenum gasket - I will search for the test procedures. I am going to try new cap rotor and wires - they have warranty. any other idea?
Old Jan 18, 2009 | 12:03 AM
JackJ's Avatar
JackJ
Unbalenced tires or bent wheels can do this to, also is you have ever used fix-a-flat or ties jack.
Old Jan 18, 2009 | 06:37 AM
JBs DAK's Avatar
JBs DAK
Broken plug wire or a cracked coil will do this,.. In-fact a crack in the porcilin on
a plug will also cause it. Bad rotor or cap too.
Old Jan 18, 2009 | 11:36 AM
st.joe68's Avatar
st.joe68
Default cap and rotor
I am going to try the cap and rotor, I went to check the cap to ensure that everything was tight and I got the Sh$t shocked out of me. Probably have a bad wire or cap... I'll let you know how it turned out.
As for the fix-a-flat or bent wheel - this is more of a jerking action vs. a shudder or vibration. don't use fix-a-flat my tire guy would hate me for it.
Old Apr 27, 2010 | 04:58 PM
tesla57's Avatar
tesla57
Default bucking and stalling
I am having the same problem but mine gets worse when the AC is on. I also have had the engine stall. It will start right back up and the engine seems to have plenty of power any ideas?
Old Apr 27, 2010 | 05:20 PM
UnregisteredUser's Avatar
UnregisteredUser
When you checked your TPS did you use a digital voltmeter? If so, try again with an analog meter so you can catch the needle twitching if you hit a dirty spot.
