Gas smell??
Old Jan 19, 2009 | 09:40 AM
johnnyrocket5363's Avatar
johnnyrocket5363
Angry Gas smell??
For about a month now, whenever I top off my tank, for a while there is a strong gas smell coming from the back half of my truck. At first, it was only for a short time untill I couldn't smell it anymore. Now, however, I'm down to a quarter tank before it stops. Also, my fuel is disappearing fast, but my overhead console shows no real change in mileage. Can anyone help?
Old Jan 19, 2009 | 10:28 AM
punkrguy's Avatar
punkrguy
I would have to say you have a leak somewhere (probably near the top) of your gas tank. Have you noticed any gas on the ground? I would check over your tank and see if theres anything noticeable thats leaking.
Old Jan 19, 2009 | 10:33 AM
dblj16380's Avatar
dblj16380
+1 on the leak.
While your under your truck, I would double check the fuel lines as well. You could have a leak there too.
Old Jan 19, 2009 | 11:55 AM
punkrguy's Avatar
punkrguy
+1 Lines
Its gotta be leaking from somewhere near the top 1/2 of the tank (or lines) if your smelling it when you fill up and your mysteriously loosing gas. Take a lighter and stick it up there so you can see better...........KIDDING!
Old Jan 19, 2009 | 11:59 AM
johnnyrocket5363
Also, what about rollover valves? Tank vents? EGR valve? I've looked, and there's no obvious leak...
Old Jan 19, 2009 | 03:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the filler/vent tubes(they rot) and hose's to the tank
Old Jan 19, 2009 | 07:45 PM
johnnyrocket5363
Okay, good point. What about the gas cap? Can I check it somehow?
Old Jan 19, 2009 | 09:10 PM
aim4squirrels's Avatar
aim4squirrels
you can run a thin film of engine oil on the O ring of the gas cap to help it seal a bit.
Also check your evap canister to make sure it's not damaged. And check the injectors and fuel rail/quick connect fitting in the engine bay.
Old Jan 29, 2009 | 03:50 PM
johnnyrocket5363
UPDATE: I pulled my gas tank, and the collar ring securing the pump and filter had came completely loose. Also, I discovered the source of a brake fluid leak: the brake line behind the tank rusted and leaked under high pressure. However, both problems are now fixed. Thanks to all!!
