Front axel problem
I have a 1998 Ram 1500 4X4. Last night I was plowing and tore the U-joint out of the passenger side front axel. As a result the outer stub is now broken, and I have to replace it and the end of the axel is deformed a little where the U-joint cups go. Is this axel still usable or do I have to replace it as well?
Jack
Jack
it depends on what "deformed a little" means.
i'd say the u-joint yoke thing is heat treated/hardened, so if you beat, or heat, it back into shape, it will either break, or severely weaken it.
so if you can get the u-joints back in without beating/heating, i'd say its ok. if not, i'd replace it.
