replacing starter
Old Jan 25, 2009 | 01:43 PM
ram4x4f's Avatar
ram4x4f
Exclamation replacing starter
trying to replace starter in a 98 ram 360,i removed bottom nut and top bolt but starter will not come off.i used 2lb hammer to tap, doesn't seem to move.any suggestions please.
Old Jan 25, 2009 | 02:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Tap it harder,
Old Jan 25, 2009 | 02:55 PM
ram4x4f's Avatar
ram4x4f
Default bad starter
hit alot harder,starter housing starting to crack,both bolts are out why would it be so hard to break loose.
Old Jan 25, 2009 | 03:14 PM
zman17's Avatar
zman17
The stud that you removed the nut from is probably corroded inside the starter housing.
