New Issues but getting better
Old Jan 25, 2009 | 01:52 PM
Vader's Avatar
Vader
Default New Issues but getting better
Okay, this will be part 2 of my rocker install woes.
This morning I readjusted the rockers and two were a tiny bit loose.
Took forever to start, cranking cranking cranking, no gas.
Finally she started, no rocker noise at all.
I have a scan gauge and have two CELs, P0320 & P0304.
All wires are tight to the dist and plugs.
I am almost there, get me home guys.
Thanks, Joe
Old Jan 25, 2009 | 02:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the #4 plug wire didn't get f'd up when you pulled it to do the install. And check all the grounds and also the wires to the distributer and crank sensor. I hope the push rod isn't bent at #4.
Old Jan 25, 2009 | 02:33 PM
Vader's Avatar
Vader
If the pusrod for #4 was bent, would I hear a funny noise?
#4 was not the rocker that was loose.
I will check the ground strap.
What size is the socket that removes the plugs?
Thanks Z
Old Jan 25, 2009 | 02:39 PM
zman17's Avatar
zman17
5/8" spark plug socket.
Old Jan 25, 2009 | 02:40 PM
zman17's Avatar
zman17
And BTW, it is good that #4 was not the loose one.
Old Jan 25, 2009 | 03:18 PM
Vader's Avatar
Vader
Okay, I pinched wire # 4 against the VC.
It has a tare in the outside cover. could that cause the misfire?
What about p0320?
Old Jan 25, 2009 | 03:20 PM
zman17's Avatar
zman17
YES, replace the wire then clear the codes.
Old Jan 25, 2009 | 06:25 PM
Vader's Avatar
Vader
Replaced runs smooth but why did it throw a P0320?
Old Jan 25, 2009 | 07:14 PM
lastrights's Avatar
lastrights
vader what your truck look like never saw a pic ??? how the performance for you ??? did you recconect the ground wire on the left valve cover it was a pita. let us know when you replace the ignition wire if it works, if not were going to think on it
Old Jan 25, 2009 | 08:30 PM
talon6's Avatar
talon6
glad you got it. how you liken the new power?
