Borgeson steering shaft
I am trying to install one on my Ram. The directions do not make sense on how it mounts to the gear box. it seems like I wiil have to modify the shaft coming out of the gear box for the shaft to mount correctly. Has anyone here installed one that has a DIY or some photos? Thanks!!!
I have not personally installed one myself, but from what I have read about them is they are a very good company and that it should be a bolt on deal. If its not, I would be calling them and asking some questions.
The shaft is a TOB ! Worth the $300. And Claymore, the only mod you might have to do is, if you have a pin about 3/4" long sticking out of the end of the stub shaft itself. Just cut it off flush with the stub shaft.
Well yes, that too. But you just need to file a small flat spot where the set screw goes, which I did after I made sure I had it in the right spot. (as in wheel straight) Once you are happy with the position, tighten the set screw a little and it will crush the splines, so you can see where to file it.
