turning off at stop light
Old Jan 26, 2009 | 09:58 PM
rene4967's Avatar
rene4967
Default turning off at stop light
i just bought a 98 reg cab short bed and when i pull up to the stop light it turns off on me. any ideas?
Old Jan 26, 2009 | 10:13 PM
98cherryram's Avatar
98cherryram
just at stop lights???? maybe it doesnt like bright red lights jk... give some symptoms, does it try to fight to stay alive, has it been doing it a long time, did it just start, does it just turn off like electric or like it lost a ton of power and just dropped to 0 rpms and quit on you???? We need these things to help diagnose, my best guess is that you arent getting the right air to fuel mixture ratio when your rpms drop to idle, possibly meaning you have the same problem I have...now the only problem with the problem that I am having is that i cant quite completely figure it out, but when I do, ill let you know
Old Jan 27, 2009 | 01:58 AM
helms's Avatar
helms
first check battery voltage, if it too low it will shut down at idle, then i would check the IAC. this is for starters, but like cherryram said, its hard to diagnose with small amounts of info.
Old Jan 27, 2009 | 07:16 AM
rene4967's Avatar
rene4967
well even just if im going down the street and i let go of the gas too quickly itll shutdown. i mean everything turns off. i have to ease off the gas slowly. and i was thought it was an air fuel problem as well but i had a 91 dodge and it would do the same thing. that turned out to be the distributor. the whole cap had melted together. but i havent had a chance to check it on this truck.
Old Jan 27, 2009 | 10:49 AM
dodge15004x45.9's Avatar
dodge15004x45.9
fule pump?
