siphon
Old Jan 26, 2009 | 10:15 PM
98cherryram's Avatar
98cherryram
Default siphon
So im working on siphoning the fuel out of my tanks so i can clear the water out and while doing so I found out that i cant seem to reach the tank with the hose that i bought, so im not sure if 4 feet of hose is just not enough, or does the tank on the dodge have some kind of thing in it that keeps you from siphoning it??????
Old Jan 26, 2009 | 11:49 PM
pcfixerpro's Avatar
pcfixerpro
Never done it, but I would assume 4ft would be too much. I bet the end of the hose is curling upwards... so the end isn't in the gas. And as far as I know there is no prevention for siphoning so I would slowly put the hose down till you think your in the tank I guess. Sorry im not much help.
Old Jan 26, 2009 | 11:58 PM
zique's Avatar
zique
Yes, it has an anti-siphoning neck. It is basically a ball that sits in the way allowing liquid to pass, but not large enough of a hole to get a hose by. If you want to siphon, you have to detach your filler neck and siphon from there.
Old Jan 26, 2009 | 11:59 PM
BIGRED97's Avatar
BIGRED97
these tanks have an anti siphon device in the filler tube. its a ball thing, best bet is to reach up and disconnect the filler tube, im trying to remember if i had the bed off when i did it, which i probably did.
four feet is plenty of hose, but not when there is blockage. sorry
Old Jan 27, 2009 | 12:01 AM
BIGRED97's Avatar
BIGRED97
sorry for the repeat, looks like zique beat me by just a moment.
Old Jan 27, 2009 | 12:06 AM
pcfixerpro's Avatar
pcfixerpro
Learn something new everyday Thanks guys
Old Jan 27, 2009 | 12:13 AM
98cherryram
well now I can get some out of it, I got the tube by it that I bought and it gets fuel, but it wont keep a constant stream, I got one of those ones with the pump in the middle...
Old Jan 27, 2009 | 01:10 AM
Mowhawk's Avatar
Mowhawk
*rainbow* The more you know...
Old Jan 27, 2009 | 01:18 AM
ophidia's Avatar
ophidia
And knowing's half the battle...
GI JOE!!!!!!!!!!!
Old Jan 27, 2009 | 08:33 AM
charlie1935's Avatar
charlie1935
If I'm not mistaken that valve is supposed to keep gas from running out when you turn over. One of the saftey features they've had over 20 years.
