Check Engine Light
Old Jan 27, 2009 | 06:49 PM
TL4X4's Avatar
TL4X4
Default Check Engine Light
hey i have a 99 ram with a 5.9L that tripped a check engine light. i went to autozone and it ran the code PO175 system too rich. what are some things that i could check and any ideas on how to fix it without paying the "man" at the shop? thanks!
Old Jan 27, 2009 | 06:58 PM
rcohen80's Avatar
rcohen80
had the same problem finally went away after installing the o2simm from fastman
Old Jan 27, 2009 | 07:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check your plenum, spark plug , spark plug wire, and injector.
Old Jan 27, 2009 | 09:04 PM
aim4squirrels's Avatar
aim4squirrels
try to clean your O2 sensors with some electric parts cleaner.
P0175 FUEL SYSTEM TOO RICH A rich condition has been reported by an abnormally large lean correction.
Old Jan 27, 2009 | 09:18 PM
Nasty Nate's Avatar
Nasty Nate
Alldata info
Coolant sensor calibration failure
engine mechanical problem
Fule pressure out of specification
Upstream O2 sensor heater
Fuel system rich or lean does not reoccur
