U joint broke again!
Old Jan 31, 2009 | 11:21 PM
  #21
olyelr's Avatar
olyelr
Originally Posted by dblj16380
I know they "suggest" in the manual that 4HI not be pushed past 55mph and that 4LO not be pushed past 25mph. I've always stuck to these boundaries just to be safe, but it can probably take more than that.
Oh for sure, its always a good idea to follow suggestions.
Its not like I speed in 4WD on a regular basis, I was just saying I have without any failures.
Old Feb 1, 2009 | 01:11 AM
  #22
Keegan's Avatar
Keegan
So I replaced the u joint again tonight, and actually welded the caps on the axle end. It looks like I'm in need of a new axle shaft... its pretty chewed up.
Old Feb 3, 2009 | 12:18 AM
  #23
01 silver ram 1500's Avatar
01 silver ram 1500
while you have everything apart you should check your hub bearing because i just went to do my u joint today and noticed that i had a bad hub.
