dodge trans issues
Old Jan 29, 2009 | 11:01 AM
carrino's Avatar
carrino
Default dodge trans issues
helo everyone
i have a 95 ram 2500 4x4 my trans went for the 4th time and i have had enough with rebuilding it. myself and 3 tranny shops. the last time myself which lasted the longest i must add. anyway does any one know if a trans out of a 99 durango with a 5.9 would bolt up to my truck i assume it would physically bolt up but what about everything else?
thanks in advance.
also does someone know if there is an aftermarket CV joint available to replace the front axle universal joints if not im going to look into producing these. those universals suck replacing them every year.
thanks in advance
Old Jan 29, 2009 | 12:12 PM
MonteC's Avatar
MonteC
If your transmission is an RH then no it will not. The RH case connector only has 3 prongs. While the case connector for the RE has 8 prongs.
