Help with Transmission data
Old Jan 29, 2009 | 04:28 PM
zteeters's Avatar
zteeters
Default Help with Transmission data
I have a 1996 Ram 1500 318 4X4. The trans went bad, I have been told I can only put in another trans from another 1996, NOT a 97-98 etc... is this true can I swap the trans with other years????? please someone Knowledgable in these matter respond quickly, I have money now but the wife has been sniffin around, and I need to move quickly..... thanks
Old Jan 29, 2009 | 04:38 PM
jarheaddoug's Avatar
jarheaddoug
I have the same question. Mine's a 2001 Ram 1500. Is there some type of transmission chart reflecting which years can be used with which model?
Old Jan 29, 2009 | 07:43 PM
MonteC's Avatar
MonteC
96-99 compadable. 00- and up, compadable
BUT, with a minor modification you can use any 46RE.
Old Feb 2, 2009 | 08:48 AM
zteeters's Avatar
zteeters
Default trany swap info
I have found a trans out of a 99 Grand Cherokee with a 5.2L eng same as my dodge, Will that trans work in my 96 dodge?
Old Feb 2, 2009 | 01:01 PM
transguy37's Avatar
transguy37
Hello,
I can't remember, but I think jeep put their starters in a different place. I will find out for sure unless somebody already knows.
Old Feb 2, 2009 | 08:15 PM
MonteC's Avatar
MonteC
The grand Cherokee used the 42re behind the 5.2L. At least every grand Cherokee ive worked on has had a 42re.
Old Feb 2, 2009 | 11:08 PM
transguy37's Avatar
transguy37
The Grand Cherokee with the 4.0 has the 42RE, the grand cherokee with a 5.2 has the 46RE.
Old Feb 3, 2009 | 08:58 AM
MonteC's Avatar
MonteC
Im sorry they werent 42re's they were 44re's. Not 46re's.
I just looked it up.
The only year the jeep Grand Cherokee used the 46RE behind the 5.2 was from 94-95.
From 96-00 it the Jeep Grand Cherokee used the 44re, which is just about identical to the 42re, only difference would be the clutch capacity.
The only Jeep Grand Cherokees ive ever worked on had the 44re. The 42re was used behind the 4.0l in the grand cherokees. But from 91-93 the grand cherokee used the AW30-40LE behind the 4.0l.
Old Feb 3, 2009 | 12:53 PM
transguy37's Avatar
transguy37
97-98 grand cherokee's 5.2 and 5.9 have the 46RE.
Old Feb 3, 2009 | 01:00 PM
MonteC's Avatar
MonteC
The ones off of the top of my head are 3 from 97-98, 2 from 99-00, and a few 96's. All were the 44re.
The 5.9's do in fact have the 46re, but not the 5.2
