Wheel Spacer
Old Feb 1, 2009 | 03:15 AM
helms's Avatar
helms
Originally Posted by 01DodgeRam360
With that said, I'm not so sure I'm crazy about that. I often tow with this truck, and use it for work. Thanks for the information.
Now hypothetically, I were to add a spacer, or get a wheel with a greater offset, should I buy longer studs for the lug nuts to go over? Wouldn't adding a spacer or a bigger offset wheel lessen the amount of thread the bolts can screw onto?
with spacers it is possible that your studs would be too short. with different offset wheels this wouldnt be a problem, the wheel flange would just be closer to the inside edge of the hoop.
