Rebuild or Replace 360?
Old Jan 31, 2009 | 12:12 PM
atp's Avatar
atp
Default Rebuild or Replace 360?
New to the tread and man has it been helpful. Here's my question:
I bought a 99 2500 with a bad motor? I was just going to drop a motor in it and sale but have decided to keep. I have been reading lots of threads on Mods and have decided to play a little. I am looking at a 360 with 115K that a board member has ($450 shipped to me) but am now thinking about rebuilding my motor. Either way i want to add a cam, do some head work, Fastman TB etc. So, should I buy the motor with 115K add a cam, heads, TB and roll or spend the money on my bottom end then do the other stuff? My budget is $1000.
Thanks
Old Jan 31, 2009 | 12:27 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
You better double, maybe triple that budget depending on what you want to accomplish.
Old Jan 31, 2009 | 01:32 PM
RM_Indy's Avatar
RM_Indy
^^^x2
1500 for a basic reman 360 I would think, then add tb, cam & heads another 2k give or take
Old Jan 31, 2009 | 04:17 PM
atp's Avatar
atp
So - buy the 117K motor and add TB, intake mod and drive on?
Old Jan 31, 2009 | 08:52 PM
helms's Avatar
helms
what part of the engine is bad?? this will determine if you need a new shortblock or not. if you have a head issue, then you can add all the stuff you want to your current bottom end. if its a block problem then you may be able to fix/machine it, if you cant, you will have to get a new one.
Old Jan 31, 2009 | 09:10 PM
atp's Avatar
atp
My problem is definitely in the bottom end. I want know until i get it apart. The motor has 250K on it.
Old Jan 31, 2009 | 09:45 PM
helms's Avatar
helms
ya, you will want to check it out, but it may not be too bad. you might be able to getaway with a basic re-build kit...and possibly a crankshaft, lol
