Welding D44
Old 02-01-2009 | 12:38 PM
pcfixerpro's Avatar
pcfixerpro
Originally Posted by olyelr
The drivers side is always locked in regardless. The difference is the front drive shaft will be spinning 100% of the time, even in 2 wheel drive.
I definitely wouldn't recommend it on a street driven truck. At minimum you would want a posi-lock system so you could disengage the passenger axle when a locked front isn't needed (most of the time). A lockout kit would be even better.
Bold 1, thats what I said.
Bold 2, it already does this anyway
Bold 3, the posi-lok doesn't help because it serves the same function as the cad. Moving from 4wd to 2wd will do the same thing.
Bold 4, As suggested in post 2
Old 02-01-2009 | 04:32 PM
olyelr's Avatar
olyelr
Bold 1 - You said "with it welded" the drivers side would be locked in all the time. I elaborated and said it is locked in all the time regardless of being welded or not.
Bold 2 - Wrong. The front drive shaft does not constantly spin when driving in 2 wheel drive. It is totally free to move until the transfer case is in 4 wheel. Go crawl under you truck when its in 2 wheel and spin the shaft to prove it to yourself.
Bold 3 - Wrong. When you put it in 4 wheel drive with a welded diff both axle shafts will be spinning. But, if he had a posi-lock cable he could unlock the passenger side and still leave it in for wheel drive (therefor only having the driver side axle in use, and in essence acting line an open diff).
Bold 4 - Who gives a fart if it was already stated, I gave the man my own opinion. You never agreed with someone else's opinion in the same thread before?
Old 02-01-2009 | 07:50 PM
helms's Avatar
helms
well, not to get into the argument, but a posi-lock on a welded diff will unlock the passanger side while in 4wd, but, it wouldnt act like an open diff. The drivers side would be locked to the rear axles, moving it at the same speed, it will still lurch around corners. you would have to be in 2wd to prevent this, but i think with a welded diff, in 2wd with the posi-lock or even CAD open, ther drag on the driverside tire due to the axle, diff carrier, gobs of weld and front DS all spinning would pull the truck to the left quite a bit.
Old 02-01-2009 | 08:08 PM
pcfixerpro's Avatar
pcfixerpro
Thats pretty much what I tried to say but I did mess up on a portion of it. oldyelr is right about the driveshaft thing (brain fart). I did not account for the transfer case in 2wd operation, but after reading helms, he has it right.
Old 02-01-2009 | 09:52 PM
olyelr's Avatar
olyelr
Yep, Ive noticed he has a way of saying stuff to easily get the point across. Well said helms.
Old 02-01-2009 | 11:25 PM
helms's Avatar
helms
haha, hey, thanks guys, its nice to be appreiciated
Old 02-03-2009 | 12:10 AM
madmax0r's Avatar
madmax0r
Ya, they pretty much answered it, I would add: Even a limited slip will turn the front axle full time... It would be better off the way it is. if you used the truck for only plowing, it might change things.. but for a daily driver
Old 02-03-2009 | 01:45 AM
helms's Avatar
helms
ARB air locker, or i guess any selectable locker for that matter. expensive but cool as hell
Quick Reply: Welding D44
