Squeaky clutch
Old Feb 2, 2009 | 04:39 PM
sugarray's Avatar
sugarray
Default Squeaky clutch
My clutch squeaks like an old door each time I push it in and release it. Is there a way to stop this? Oil it? Where is it coming from? My fluid is ok, and no whining or slipping during shifting.
Old Feb 2, 2009 | 04:44 PM
helms's Avatar
helms
this happens to the pedal assembly all the time. Find the pivot point for the clutch pedal and lube it up with some spray lube, its not a permenant fix but itll stop for a while. In most vehicles there is a nylon bushing that goes into the pivot hole and the pivot shaft goes through it, this is most likely worn out or super dry, check it out.
