Air vents switch around on their own...
Old Feb 3, 2009 | 12:39 PM
ram1500_'00's Avatar
ram1500_'00
Ok I admit i was wrong. But hey be easy, i've never heard of this problem. So now curiousity has me wanting to rip my dash apart and look around.
Old Feb 3, 2009 | 12:40 PM
Viper37's Avatar
Viper37
Originally Posted by VWandDodge
Under the battery is a vaccum line that is known to rot and break. When this fails it is known to produce the symptoms you've described.
That's for cruise control models only right?
Old Feb 3, 2009 | 12:47 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I'm fairly certain it was the air vents I know if you check around this forum you'll find the answer. Either way, it is a vacuum line issue.
Old Feb 3, 2009 | 01:44 PM
G&L01's Avatar
G&L01
I think the lines for the cruise and the lines for the vent controls t-off from the same place from what I've seen under my hood so far...
I hunted around town and found a generic vac check valve that works with a couple of adapters to make it fit. Dodge had to order a whole harness for that area and I would have had to wait for a few days to get it. It was about $16 to go that route, so not too pricey, but all I needed was the valve. Spent 5 bucks for it at O'rileys.
Here's some pics of the little valve and where it's at. Probably no bigger around than a nickel.
A close up...
What it looks like out...
Here's what the replacement looks like with my little adaptor riggin...
So, that's how far I've gotten. I'm going to take it out and drive it around awhile, try the vents & the cruise and all that, & I'll let you guys know what happens.
Old Feb 3, 2009 | 02:03 PM
dakotas ram's Avatar
dakotas ram
maybe you have a plenum leak and youre loosing your vac
Old Feb 3, 2009 | 05:12 PM
G&L01's Avatar
G&L01
Yep, go somethin' else goin' on cuz we just took it out for a spin awhile ago and the symptoms persist despite the new valve. It works just fine around town but once you get up to highway speeds and start hitting hills she starts doing the same again.
Old Feb 3, 2009 | 05:45 PM
95MaroonMonster's Avatar
95MaroonMonster
mine does the same thing, it goes to defrost when i load the motor up [heavy throttle]
Old Feb 3, 2009 | 05:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1, and that would be the vac line for the cruise control.
