Q's about TB's and 14x3 air cleaner
Old Feb 6, 2009 | 02:41 PM
CSXfan's Avatar
CSXfan
Default Q's about TB's and 14x3 air cleaner
Hi all,
I want to start messing with some intake mods since I already have a high flow cat and a FM muffer. I want to go with the mopar performance air cleaner with the K&N 14x3 filter. I will be adding shortie headers some time in the near future too. My questions are....
1. Do I need to get the Fastman throttle body in order for the round filter to fit, or can I use my stock TB?
2. How hard would it be to bore out my stock TB to 52mm? I'm having a hard time paying 300 bucks for an all new TB when I could just mod my own, or a $20 one from the junk yard.
Thanks
Old Feb 6, 2009 | 03:02 PM
iwhitne's Avatar
iwhitne
it'll fit the stock TB... might have to bend the post a little to line it up right
I'd say if you know how to bore it out.. go for it
doing both will prolly give you less mpg... more air=more gas
Old Feb 6, 2009 | 03:23 PM
dakotas ram's Avatar
dakotas ram
i took my tb and bored it myself.....not as great as a fastman but nowhere near the price either
Old Feb 6, 2009 | 03:31 PM
dodgeram07's Avatar
dodgeram07
well the stock tb is 50mm down to 48mm bore so it wouldn't all that hard to make it 50mm all the way throw.... but the 52mm all the way throw will be hard because you will need to replace the buterfly values.. good luck withe mod
Old Feb 6, 2009 | 03:37 PM
PurplDodge's Avatar
PurplDodge
What did you use to bore it out? I was thinking a 50mm Drill bit on a drill press. But I cant find one anywhere.
Old Feb 6, 2009 | 03:44 PM
Silver_Dodge's Avatar
Silver_Dodge
You'll need new butterfly valves on the 50mm too since they are located about halfway down the bore.
Old Feb 6, 2009 | 05:33 PM
Jpnorris87's Avatar
Jpnorris87
50mm=5cm=1.968502937in=1 31/32in (1.96875in) By my redneck math, you are looking for a 1 31/32in drill bit. I dont think they make one that size but you can try.
Old Feb 6, 2009 | 06:12 PM
lv360ram's Avatar
lv360ram
Now that's some common sense right there and I'm not being sarcastic.
Old Feb 6, 2009 | 06:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If this was so easily done, Fastman and others would not be selling them. No matter what you do, you need new plates. Good luck with that.
Old Feb 6, 2009 | 07:33 PM
shawngrace5's Avatar
shawngrace5
I agree, I think that has disaster written all over it, I'm a cheap bastard and I wouldn't even do that I'd rather just slap a Fastman on it.
