Lug Nuts don't stay put
Old 02-07-2009 | 12:55 AM
Harrison_Bergeron's Avatar
Harrison_Bergeron
Default Lug Nuts don't stay put
I have a problem with my lug nuts loosening up and ultimately falling off. The problem is on one lug on each of the front wheels of my '95 2wd 1500. It has only been 3-4 weeks since I replaced them last and they are already loose again, but the other eight are fine. Does anyone know what may be causing this, or how to prevent it?
Old 02-07-2009 | 01:35 AM
EricCartman's Avatar
EricCartman
Torque them suckers down... like 100 ft lbs or so. You might be able to go with a little bit of low-strength lock-tite or something... but you shouldn't be dropping lug nuts like that.
When you torque them down, do the first lug nut, then tighten one on the other side until you work your way around the whole wheel.
Good luck!
Cartman
Old 02-07-2009 | 02:03 AM
Bloodknight80's Avatar
Bloodknight80
Try checking the threads on the stud. Could possibly be stripped? That or someone is effin with you.
Old 02-07-2009 | 02:46 AM
hometheaterman's Avatar
hometheaterman
Check the nut and threads. What are you torquing them to? They need to be torqued to 100 ft lbs. I'd recommend doing them with a torque wrench by hand also not with a impact wrench with or without a torque stick. I'd do them by hand especially if I was having that issue. You also know to tighten them in a star like pattern right? Once tight go back around and make sure all are tight.
Old 02-07-2009 | 07:43 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I have the same prob on mine. I tighten them to 130 now and all is good. Brand new lug nuts too and they still come loose at a 100 lbs.
Old 02-07-2009 | 10:21 AM
aim4squirrels's Avatar
aim4squirrels
your threads are most likely stretched out. more torque will work, until the threads can't take it and strip out. then you have to replace the stud.
Typically this happens by using an impact wrench to tighten down the lug nuts, instead of torquing to spec. I believe spec is either 85 or 95 ft/lbs. should be in the owners manual.
Old 02-07-2009 | 01:36 PM
zman17's Avatar
zman17
I have never used an impact to put them on, but who knows what the PO did. And 95 lbs is the torque spec. However, if I tighten them to 95, they are loose within 20 miles or less.
Old 02-07-2009 | 01:39 PM
maverick_124's Avatar
maverick_124
i always torque to 110 foot pounds. no matter the car or truck
Old 02-07-2009 | 02:10 PM
dodgeram07's Avatar
dodgeram07
aluminum wheel are bad for lugs losein up.
Old 02-07-2009 | 10:33 PM
guitarking135's Avatar
guitarking135
yes agreed aluminum wheels are very bad and if its a 95 they are probably getting walard out and are going to need to be replaced been there done that and after new studs all around and steel wheels I was all good again. Another problem with that is in effect over tightening. 110 is what Tire shops will tighten to its kinda the standard you tighten to o tight and you do one or both of two things. you pull your lugs through or you twist them and they snap off. Check your wheels for key holing. Basically the hole being flared out if they are Replace the wheels and replace them soon.
