Rebirth of T.B. Spacers???
Old Feb 7, 2009 | 05:44 PM
Rockyhigh360's Avatar
Rockyhigh360
Default Rebirth of T.B. Spacers???
With this (new) FI air gap out, one would think that those waste of 100$ spacers might fit this intake better than our stock keg style. In the FI, air is now being directed straight to the heads instead of slamming against the belly pan. So this vortex of air might prove to be useful now in our small blocks. Just an idea.......
Old Feb 7, 2009 | 05:56 PM
aim4squirrels's Avatar
aim4squirrels
You won't get one on with the new intake. At least not with a 14X3 air hat, the is NO room to spare as the new air gap sits about a 1/4 higher than the old intake. I can barely get my air hat on and off now.
The air still "slams" a 90* angle when it hits the bottom of the intake and shoots down the runners. I'm still skeptical that you could maintain a "twisting" or "spiraling" effect to the air down the runner, but it would be more probable on the new intake.
It's a possibility on a stock setup, though I don't think the spacer + stock air hat would rival the 14X3 element. I won't believe anybody that doesn't produce before and after dyno numbers.
Old Feb 7, 2009 | 05:59 PM
Rockyhigh360
Do you still hear the hiss of air with new intake? Does the adapter plate look restrictive, or does it all match up well
Old Feb 7, 2009 | 06:09 PM
aim4squirrels
The adapter plate is in no way restrictive, it's a complete oval under the TB and gets bigger from there. it basically shrinks the 4bbl to a 2bbl. you could run one of those mammoth 58mm TB's and the adapter plate would still not cause a restriction.
There is still a bit of hiss but it is greatly reduced and not noticeable after the engine heats up, which makes me think that what you're actually hearing is the IAC valve thru the filter material which gets muffled by other air hat types.
What is noticeable is the sound of the engine with the new intake when you step into it. It's just different, you'd have to hear it to understand exactly. Here's a vid I shot, but it doesn't really do it justice:
http://www.youtube.com/watch?v=ZAoTd6WaksI
and another:
http://www.youtube.com/watch?v=wl56bDPOls8
Old Feb 7, 2009 | 06:26 PM
Rockyhigh360
Worth the 750$ or did you get it for 600 bones?
Old Feb 7, 2009 | 06:52 PM
BlueBeast2's Avatar
BlueBeast2
AIM dont you have the old air gap or did you get a new one?
Old Feb 7, 2009 | 10:59 PM
aim4squirrels
I have the old one, but it is the exact same thing, just welded instead of cast like the new one.
Old Feb 7, 2009 | 11:08 PM
BlueBeast2's Avatar
BlueBeast2
Is it worth it? Like would I really benifit from it with the mods I'm doing? I'm really considering it but not completely sold on it yet.
Old Feb 7, 2009 | 11:20 PM
pcfixerpro's Avatar
pcfixerpro
With that stock replacement cam, stock replacement heads.... what do you think? LOL jk man. I'd go for it
Old Feb 7, 2009 | 11:30 PM
BlueBeast2's Avatar
BlueBeast2
I have pondered getting my heads ported. If Smith wouldn't be taking so long on my engine I would have asked him what that would cost.
