transfer case problems on a 99
Old Feb 11, 2009 | 07:05 PM
Tani1500's Avatar
Tani1500
def sounds like the CAD ( central axle disconnect) is getting hung up and not engaging right. if it was the t case itself diconnecting it would make a loud bang. check that first. u can get a tcase from a junk yard for like 350. there also very easy to work on. just takes the dealer weeks to get some of the parts it seams lol
Old Feb 15, 2009 | 01:14 AM
mxzrevman's Avatar
mxzrevman
thanks again for the help guys
Old Feb 16, 2009 | 09:49 PM
RAMLIFT's Avatar
RAMLIFT
My transfer case has a rattling noise when it is in 2wd then when I put it in 4wd as Im rolling a hear a grind then a loud click then it is in 4. The last time this happened though during a snow storm 4wd didnt work even though it was engaged. My cv shaft was no good but I replaced that. Anyone has a pic or link where I can see pics of a tcase. Im going to take the cover off and inspect it. Thanks
Old Feb 17, 2009 | 05:51 PM
wjxavier's Avatar
wjxavier
it would make life easier if you just replace the transfer case with a good certified used one. i had problems with mine and i bought one for 450 and me and a buddy just removed and replaced and it's been good to go since.
Old Jan 30, 2014 | 08:07 PM
ramit403's Avatar
ramit403
Originally Posted by helms
transfer cases are really simple to work on. you have a new truck, so if the fix isnt obvious on the outside, dont be afraid to rip into it, it could be a simple thing, like a shift fork or a dog ring... if it is its a cheap fix, if it isnt... you were gonna buy a new one anyway. gl
Hey I have a question ya seem like what ya talkin bout I have a 99 dodge ram 1500 4x4 with the 5.2
In it now I throw it into 4 wheel drive and it engauges but while im driveing or going up a hill it jumps in and out of 4x4 in both 4 hi and 4 lo what would your opinon on it be ?
Old Jan 30, 2014 | 08:08 PM
Erm, five year old thread....... but, kudos for searching at least.
Old Jan 30, 2014 | 10:22 PM
Ramking9610's Avatar
Ramking9610
I had a similar problem on my 1994 dodge ram 1500 5.9l. It felt like it went into 4wd but only the back tires would spin. You could feel the difference in torque too (like 4wd should). Turns out it was the 4wd actuator on the right side of the axle. $60 at your local parts store. 15 minutes to replace!
