Quick axel question
Old Feb 9, 2009 | 07:22 PM
MAJohns's Avatar
MAJohns
Default Quick axel question
where can you find out what axles you habe has far as Dana 60,70, or 80 i need to know what fluid to use the book says... 9-14" rear axel uses 75W-90 and the dana's use 80W90. which one aplies to me?
Old Feb 9, 2009 | 07:24 PM
PurplDodge's Avatar
PurplDodge
You have a Dana 44 up front. And you have a Chysler 9.25 in the rear.
Old Feb 9, 2009 | 07:26 PM
MAJohns's Avatar
MAJohns
ok thanks
Old Feb 9, 2009 | 07:30 PM
MAJohns's Avatar
MAJohns
so i guess i need 75W90 in the rear and 80W90 in the front? the book is not real clear on that
Old Feb 9, 2009 | 07:47 PM
dhvaughan's Avatar
dhvaughan
honestly it doesn't make any difference. i used the valvoline 80w90 or 85w90, don't remember which, in both my front and rear. its all GL5 rated.
Old Feb 9, 2009 | 08:03 PM
MAJohns's Avatar
MAJohns
ok i will just go with 80W90. how much do i need for both front and rear do you know?
Old Feb 9, 2009 | 08:32 PM
dhvaughan's Avatar
dhvaughan
from the service manual. 10 pts = 5 qts for both.
FRONT AXLE
The lubricant should have MIL-L-2105C and API GL 5 quality specifications.
Lubricant is SAE 75W-140 SYNTHETIC gear lubricant.
REAR AXLE
Lubricant is a thermally stable SAE 80W-90 gear lubricant.
Lubricant for axles intended for heavy-duty or trailer tow use is SAE 75W-140 SYNTHETIC gear lubricant.
NOTE: Trac-lok and Vari-lok equipped axles require a friction modifier be added to the lubricant.
FRONT AXLE
Model 216-FBI 2.3 L (4.8 pts.)
REAR AXLE
9-1/4 inch 2.1 L (4.5 pts.)
Old Feb 9, 2009 | 10:18 PM
MAJohns's Avatar
MAJohns
ok thanx
