Rough Engine
Old Mar 2, 2009 | 05:44 PM
  #41
Formosa Joe's Avatar
Formosa Joe
Q888,
I had a slight (felt like misfire) shuddering, shaking at around 1500 rpm ('95 with 5.2 and no cat) just like you are describing. This is after I changed a non-working injector. I put a can of seafoam in my FULL tank of gas and now I am just below 1/2 tank and the truck runs GREAT. Have you tried this?
Laters
Joe
Old Mar 15, 2009 | 11:08 PM
  #42
Mikewp64's Avatar
Mikewp64
Default Fixed?
Did you figure out your problem?,,,My 98 1500 is doing same thing,
Old Apr 4, 2009 | 02:37 PM
  #43
Q888's Avatar
Q888
Fixed the shutter (read: vibration shaking).
Harmonic Balancer (vibration dampener) $89.95 OEM Part
Front Crankshaft Seal (while I was there) $12.89 OEM Part
Took me about 2 hours and less than a six pack.
No more shutter, shake, vibration, or misfire feeling.
What a great feeling. I was really starting to get annoyed with this and imagining the worst. Trans going out, torque converter problems, cracked head, and you name it. Glad it was something simple.
I diagnosed this by removing the serp belt which disabled the accessories then started the engine for a minute. Engine still exhibited shutter so I shut it off and got under the front end to inspect the main drive pully assembly and harmonic balancer. I found with a strong enough grip on the drive pully I could get the balancer to spin without turning the engine.
Old Jun 25, 2009 | 09:56 AM
  #44
FoxMulder's Avatar
FoxMulder
Sorry to revive an old thread but to be clear...when you changed your harmonic balancer it cured the rough idle?!
