95 2500 5.9 need help asap
Old Feb 10, 2009 | 02:21 AM
joshk08's Avatar
joshk08
Default 95 2500 5.9 need help asap
I'm considering buying a 95 2500 5.9 360 5 speed really soon, there is already other offers on the truck so I have to act fast.
The truck has a 3inch body lift and the linkage wasn't adjusted, the owner says that while driving if you hit the brakes hard it will try to shift into 4x4, also the instrument cluster completly doesn't work, and it needs tie rod ends, and ball joints, and a 4x4 half axle. I was just wondering if anyone would know why it would try to shift into 4x4 like that, as well as any other opinions anyone may have. How much does anyone think it would cost to fix everything, and what would this truck be worth?
Thanks,
Josh
Old Feb 10, 2009 | 07:06 AM
dblj16380's Avatar
dblj16380
My best guess on the 4x4 shift problem is that when the truck got lifted, the linkage was just stretched out and it is now stretched to the max. (There are a couple of rods linked together that you can move around a bit.) When you hit the brakes hard it will tend to rock the truck body forward and being that the linkage is already tight it pushes back on the transfer case and shifts it.
I don't know how much the total repair would be. If your looking for AutoZone stuff, then balljoints are probably 80 for uppers and lowers and I think both tie rod ends would run about 60
Old Feb 10, 2009 | 06:55 PM
joshk08's Avatar
joshk08
Do you know how I could adjust the linkage or add a link?
Old Feb 10, 2009 | 09:04 PM
helms's Avatar
helms
if you dont know what your getting yourself into, it would probobly be better to leave this truck alone. the last thing you want is to get it home and find more problems, or it will cost a fortune to fix whats wrong
Old Feb 10, 2009 | 09:22 PM
dhvaughan's Avatar
dhvaughan
i wouldn't buy it unless he's giving it away for about $1000-1500. it sounds like a fixer-upper that went downhill instead of up. by the time you fix the front end, lift/shifter, possible cluster (god knows whats wrong with that, anthing from .50 fuse to major wiring), you could sink a bundle.
Old Feb 11, 2009 | 06:55 AM
dblj16380's Avatar
dblj16380
I'm not sure how to do it, or even if that is the issue. That is just my best guess. I would imagine it might not be too terrible to tackle, but again, i've never done it.
If you surf through the forum there is probably a thread about how to do it somewhere.
Old Feb 11, 2009 | 09:57 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Sounds like a basket case. PASS!
Old Feb 12, 2009 | 08:09 PM
joshk08's Avatar
joshk08
It was priced $1500 but I could have bought it for $1000, the truck is now sold, and I didn't buy it. Thanks for everyone's help...
