20w50 VR1 Engine Oil
Old Feb 14, 2009 | 04:17 PM
Acapalic's Avatar
Acapalic
Exclamation 20w50 VR1 Engine Oil
I just put in 3 quarts 20w50, 2 quarts 50 (just cause i was a idiot when buying and didnt relise i grabed 3 quarts (I flush the old oil out with 1 quart of new oil) of sae50) of Valvoline VR1 Engine oil, Is there anything i should worry about using 50w oil? I like to try differnt brands of oil , and Valvoline VR1 was up next . Supposedly it helps keep engine bearings alive longer with added ZDDP (zinc). I noticed I had a Slight valvetrain noise after I changed oil but engine felt more responsive slightly. I have 124k Miles on the clock. Let me know what you guys feel I should keep my eye out, Dont want to **** my self over by using 50w oil.
Old Feb 14, 2009 | 06:34 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Since you ask for opinions, guess what...
Unless your bearing tolerances are as wide as the Grand Canyon, there is no reason for you to run 20W-50 and/or SAE 50W. Since you are in NY, I would expect that you will experience several more days of sub-freezing temps. If it gets too cold, your starter may give up its ghost struggling to turn the engine over. As for ZDDP, that is only a concern if you are running a flat tappet cam. It's meaningless when used with our engines. IMHO, I would drain that stuff out and put 10W-30 back in.
Old Feb 14, 2009 | 08:45 PM
Acapalic's Avatar
Acapalic
I apperciate ur opinion, Just wondering , if i dont drain it out , and keep it in , will i have problems?
Old Feb 14, 2009 | 10:13 PM
dhvaughan's Avatar
dhvaughan
the only problem that i can foresee might be sluggish starting on a -0* morning. if you experience that, change your oil. if no starting issues, then it'll be ok.
Old Feb 14, 2009 | 11:04 PM
Rex-TheDOGG
Do you have a block heater?
Old Feb 15, 2009 | 09:44 AM
Acapalic's Avatar
Acapalic
Nah, But I have a Oil Cooler, Tranny Cooler, And a Remote Oil Filter Mount On the way.
Old Feb 15, 2009 | 08:18 PM
PurplDodge's Avatar
PurplDodge
That'll help.
