Timing Setting
Old Feb 14, 2009 | 05:24 PM
RAZRAM's Avatar
RAZRAM
Default Timing Setting
What is the timing setting supposed to be for the 5.9l 360? I think my timing may be off.
Old Feb 14, 2009 | 07:22 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
There's a notch under the distributor cap where the rotor should be lined up for #1. After that, the PCM will compensate for the timing.
Old Feb 14, 2009 | 09:14 PM
froesen's Avatar
froesen
You really can't set the timing on these. Timing reference is off of the crank position sensor, and as VW said the compy takes care of the rest. Cam sensor is for fuel synch. Some guys have notched the crank sensor in order to make it adjustable, but this isn't really recommended. Why do you think your timing is off?
Old Feb 16, 2009 | 10:53 PM
RAZRAM's Avatar
RAZRAM
i think it is off because i get 6.5mpg and also there is a slight tick/ping.
Old Feb 17, 2009 | 01:38 AM
xskylinedx's Avatar
xskylinedx
Have you checked for a plenum leak?
Old Feb 17, 2009 | 02:29 AM
helms's Avatar
helms
This is a quote from ALLDATA
DISTRIBUTOR
The 5.9L V-8 engine is equipped with a camshaft driven mechanical distributor containing a shaft driven distributor rotor. All distributors are equipped with an internal camshaft position (fuel sync) sensor.
The camshaft position sensor provides fuel injection synchronization and cylinder identification.
The distributor does not have built in centrifugal or vacuum assisted advance. Base ignition timing and all timing advance is controlled by the Power-train Control Module (PCM). Because ignition timing is controlled by the PCM, base ignition timing is not adjustable.
The distributor is held to the engine in the conventional method using a holddown clamp and bolt. Although the distributor can be rotated, it will have no effect on ignition timing.
All distributors contain an internal oil seal that prevents oil from entering the distributor housing. The seal is not serviceable.
Old Feb 17, 2009 | 05:16 PM
RAZRAM's Avatar
RAZRAM
how can i check for a plenum leak?
Old Dec 9, 2019 | 06:48 PM
KYCARHUSTLE's Avatar
KYCARHUSTLE
Default timing setting
i realize has nothing to do with timing its something else i can cross the solenoid and it continuously turns like it should i get back in cab turn it over cuts it off after couple seconds idk new one on me lol
Old Dec 9, 2019 | 06:49 PM
KYCARHUSTLE
Old Dec 10, 2019 | 09:16 AM
You should start your own thread, and tell us what you are driving.....
