Electrical problem
Old Feb 14, 2009 | 07:27 PM
ASSCLOWN's Avatar
ASSCLOWN
Default Electrical problem
Just started having a strange issue with my right directional. It blinks fast when right directional is activated, The parking light filament in the bulb lights up NOT the turn signal filament and when the headlight switch is pulled out, I do not have a right directional at all and the right directional indicator on the dash lights up.
The bulbs are fine.
It seems as thought the directional circuit is shorted to the parking light circuit. Is there any suggestions you guys have before I start ripping harnesses apart?
Old Feb 14, 2009 | 07:45 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Faulty flasher relay?
Old Feb 14, 2009 | 10:29 PM
ASSCLOWN's Avatar
ASSCLOWN
Hmm... thats a thought. Something easy to eliminate anyway. Actually when I have the right directional on and pull the bulb out, the flasher buzzes. Not that it means that is the problem.
It seems like I'm getting backfeed into the circuit somehow.
Old Feb 14, 2009 | 10:42 PM
dhvaughan's Avatar
dhvaughan
i'd remove the bulb and check the socket for gunk. spray it out with electrical cleaner or wd 40. test for voltage.
Old Feb 16, 2009 | 10:06 AM
APA228's Avatar
APA228
You have a bad ground. The signal light is sending current backwards through the parking light and grounding at other lights' grounds. When you turn on your other lights this path disappears because the lights are using the ground points themselves, and the current from the turn signal can't get to ground. Clean the socket and check and clean the ground connection.
Old Feb 17, 2009 | 10:50 PM
ASSCLOWN's Avatar
ASSCLOWN
APA228 your exactly right! It was a bad ground wire leading to the bulb socket! Thanks!
