replacing lower control arm
Old Feb 15, 2009 | 09:34 PM
pipman97's Avatar
pipman97
Thumbs up replacing lower control arm
how big of a job is it gonna be to replace the lower control arm on the passenger side of my 97 2wd ram ???
its bent and makes my truck sit a whole inch lower on that side so im going this week to a savage yard and pick one up .Ill do ball joints while im at it
Old Feb 15, 2009 | 10:05 PM
dodgeram07's Avatar
dodgeram07
it shouldn't be real bad just be careful with the spring. besides doing the bjs it just three move things to take off shock them c-arm bolts....use a jack to support the c-arm when taking out the shock with slowly let it down the spring still has presure on it.
heres a diy i did on the bjs https://dodgeforum.com/forum/2nd-gen...placement.html
good luck with the project...hope i help sum
Old Feb 15, 2009 | 11:01 PM
dillonjm's Avatar
dillonjm
Control arm is pretty easy, Ball joints will take a little more time but not hard IIRC (only done one 2wd). Good to do it all at once I suppose.
