Transmission Cooler
Old Feb 18, 2009 | 07:59 PM
  #21
PurplDodge's Avatar
PurplDodge
Originally Posted by Gwub2005
By too big I mean't the ones so big they require any extra tranny fluid than normal w/ the ones at uhaul they don't require any extra at all. They look pretty mush just like the stock one on my truck.
How does adding an external cooler not add any fliud? That makes no sense to me.
Old Feb 18, 2009 | 08:42 PM
  #22
xskylinedx's Avatar
xskylinedx
Thats why I went with the 4590 series flex-a-lite. Its a 6 pass rated for 26,000 GVW with
an electric fan attached to it. With the thermal sensor it will only come on at 180* which
should keep my tranny fluid temp right where it should be. Thats my theory and I'm stickn
to it :-)
Old Feb 22, 2009 | 10:16 PM
  #23
PurplDodge's Avatar
PurplDodge
What do you guys mount it with?
Old Feb 23, 2009 | 06:58 PM
  #24
Gwub2005's Avatar
Gwub2005
there is not enough fluid pulled from the tranny to require any additional fluid. And some coolers comme w/ these long plastic sticks kinda like wire ties that u push through ur radiator and slide clips on the end. then there are some that have brackets bolted to the frame.
Old Feb 23, 2009 | 07:09 PM
  #25
PurplDodge's Avatar
PurplDodge
Would those zip-ties hurt the condenser?
Old Feb 23, 2009 | 10:17 PM
  #26
hometheaterman's Avatar
hometheaterman
Originally Posted by Silver_Dodge
Well, if by doesn't do any harm you mean it doesn't work at all, then by all means get that cooler. I have tested plate coolers of that same size, and they made absolutly no difference in trans temps. You will not damage your trans by having temps too cool, escpecially when we are only talking about 20-30 degrees below normal. If you ran with trans temps at 50 degrees all day, then ya, you might have an issue. But keeping your trans temps in the 160-180 range will not do any damage, and will help the life of your trans.
Now it's fairly cold out as in the 20's and 30's mostly here but I'm not seeing my gauge go much over 100 with my B&M cooler. It stays right around 100 if doing interstate driving and what not. When it's been slightly warmer I've seen it get up to 120. The only time I've seen it get much higher is going up a 3+ mile gravel road that is very much uphill going to our place in the mountains. It will jump to around 150-180 then. For normal just freeway driving though it seems to stay right around 100-120. Is this damaging anything?
Old Feb 23, 2009 | 10:55 PM
  #27
aim4squirrels's Avatar
aim4squirrels
HTM,
Are you bypassing the radiator trans fluid heat exchanger? If you aren't, I think you might have a wonky temp sensor. Even if you are even running a 180* T-stat, it should cause the exchanger to run trans temps above 100-120. Is the cooler Pre or Post-Exchanger? Also, where is your temp sensor located?
Old Feb 23, 2009 | 11:19 PM
  #28
Silver_Dodge's Avatar
Silver_Dodge
Mine rarely gets over 110 all winter long, and i'm still running it through the radiator cooler. Just too cold for it to warm up much. It shouldn't hurt anything.
Old Nov 12, 2013 | 09:34 PM
  #29
3ares's Avatar
3ares
New Member
Default transmission cooling fan
My 2005 Ram; Cummins has a Goering billet transmission. Towing our 30' fifthwheel at highway speeds the tranny runs around 170 degrees. But in slow trafficor backing that sucker will get up to 220 or more if I don't take precautions.I'd like to add an electric fan to supplement the factory fan, how much fan doy’all think I'd need?
Keep the greasy side down.
Old Nov 12, 2013 | 11:02 PM
  #30
adam8781's Avatar
adam8781
220 is a nightmare on your tranny
How big is your cooler now? a fan that covers its entire surface is ideal. And I would put a derale in line thermostat in the transmissions cooler out line. The fan kicks in at 180f and off once the fluid reaches at 165.
