98 1500 Idle Issues and a few questions
Old Feb 19, 2009 | 01:22 PM
terranova's Avatar
terranova
Question 98 1500 Idle Issues and a few questions
Whenever I turn my truck on and if I let it idle for too long it starts to sputter and make a really loud high pitched hissing noise coming from the engine. I have a gutted Catalytic Converter and I know my O2 sensors are bad but It sounds like an air intake problem to me but im not sure. I'll try to get a better video of it later so you can actually see and hear what it's doing. It happens without fail nearly every time I start the truck and let it idle for a few minutes. I noticed also that the engine starts to shake and wobble violently as if its miss firing possibly? I don't know what the deal is. My RPM's are speratic as well, they drop to 250-300 RPM at times and I give it gas and it takes it a few seconds to actually start climb in the RPM's, like its almost flooded..Any help would be great! Also, some input on a decent Catalytic Converter that is California legal but hopefully wont rob me of performance would be appreciated as well as O2 sensors. Im full of questions today :P heres a link to a youtube video I just posted up so you can hear what its doing.
http://www.youtube.com/watch?v=1RaQ-aZvn0Q
Old Feb 19, 2009 | 03:34 PM
TMS Bill's Avatar
TMS Bill
When you walked around the back of the truck, that rattling sure sounded like the cat had clogged/collapsed ... but it's been gutted. How are you manageing that in CA?
Old Feb 19, 2009 | 04:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Remove and clean the IAC and TPS and the holes they go into on the throttle body.And as far as the cat goes, get a Magna Flow. They have them at Summit, Jegs, and can be found on ebay also.
Old Feb 20, 2009 | 11:14 AM
terranova's Avatar
terranova
How would I go about cleaning the IAC Valve and the TPS?
Old Feb 20, 2009 | 11:25 AM
Ramman18's Avatar
Ramman18
+1 on the IAC. Remove the filter assy, then remove the throttle body. You can search for "clean your throttle body" as I did a write up on it a year or so ago. The IAC is the motor attached at the rear with the piston-like thing sticking into the TB. That area gets terribly gunked up with carbon. Get some cleaner and go to town with it. Should help.
Old Feb 20, 2009 | 01:30 PM
dodgeram07's Avatar
dodgeram07
+2 on the claening, also while your cleaning go ahead and look down the into the intake and see if there's poles of oil.
edit= also take a look at the dis cap and rotor, my old dodge ran very rought at idle, new rotor and cap run just fine, then later i put nes wings on
