need help with upgrades???
Old Feb 20, 2009 | 09:16 PM
jarebear86's Avatar
jarebear86
Default need help with upgrades???
what kinda upgrades can i do to my truck for the engine or transmission or the computer that wont cost me an arm and a leg i got all the tools and a truck lift to do it all and know how but i want to gain some hp and torque but dont wanna spend too much so if anyone has any ideas please let me know no matter what they are and if yall know any sites or good name brands that would always help too.
Old Feb 20, 2009 | 09:17 PM
jarebear86's Avatar
jarebear86
also is a throttle bosy spacer worth it??
Old Feb 20, 2009 | 09:57 PM
jarebear86's Avatar
jarebear86
what kind of upgrade will shorty headers provide for me
Old Feb 21, 2009 | 05:29 AM
RM_Indy's Avatar
RM_Indy
Taller gears will help out, 410 minimum with those 33s (could search the wreckers)
Hand port your tb, remove the ridges, feather its opening at the top
Remove the intake manifold, cut the runners back about 1.5" and remove the divider. Gasket match the openings. If the plenum gasket is leaking be sure to get a Hughes plenum kit for the bottom of it.
Find a set of 1.92 valved bare EQ heads on ebay and swap your valves/springs over and add 1.7rr ontop(may find used on forums/ebay). Should give a nice gain.
Modify the bracket for the crank position sensor so you can advance the timing a couple degrees.
Shorty headers will help a little bit
Put a h/f cat on or delete it if no etest where you live
Forget the throttle body spacer, they are junk
Old Feb 21, 2009 | 05:33 AM
jasonw's Avatar
jasonw
Site Moderator
+1 for what RM_Indy said. He knows what he's talking about.
+10000000000000000000000000000 for his comment on the throttle body spacer. They do not work on our trucks. Best case it won't help at all, worst case sometimes they actually rob you of power.
