Why buy aftermarket stuff to fix your plenum gasket? LOL
Old Feb 22, 2009 | 11:24 PM
BlueBeast2's Avatar
BlueBeast2
Originally Posted by ophidia
Ok...
referring the the OP. He only has 16 posts which means he's new. That being said he probably has no experience with the pan gasket failing more then once. Also he's looking for a cheap way out that will cost him more in the long run
Old Feb 22, 2009 | 11:25 PM
ophidia's Avatar
ophidia
Gotcha.
Old Feb 22, 2009 | 11:48 PM
Silver_Dodge's Avatar
Silver_Dodge
While the steel/alum plenum plate is a contributing factor to the plenum gasket failure, my research indicates that it is not the root cause, only a symptom. The true cause I believe is the depth of the intake plenum pan bolt holes (or the length of the bolts, however you want to look at it). Because the bolts are too long or the holes too short, when the plenum pan bolts are torqued, they are only bottoming out in the holes, not actually torquing the plate down to the manifold to spec. This then allows the heat expansion from steel versus alum to cause the gasket between the un-tightened surfaces to fail. So an easier (and cheaper) fix then a 1/4" alum belly pan might be to just get shorter bolts and reinstall the stock belly pan. But, the thicker aluminum pan is probably the best fix overall since it solves both the bolt hole depth issue and the aluminum-v-steel issue at the same time.
Old Feb 22, 2009 | 11:54 PM
ophidia's Avatar
ophidia
I remembered reading that in one of your posts somewhere, so I tried screwing in one of the bolts w/o the pan being in place, and discovered it to be true. I ground off the ends of the bolts with a dremel until they were short enough. You don't have to take much off. The threads don't go all the way to the end so no thread damage occurred.
Old Feb 23, 2009 | 03:47 AM
Jpnorris87's Avatar
Jpnorris87
Originally Posted by burnnxs
I'm about to fix my intake and continue doing maintenance on the truck but I want to share something Im going to do with the gasket.
I say this because I recently learned about this truck's intake plenum gasket taking a dump every so often and if you don't buy a "kit" of some sort it will always go to **** and maybe after you buy this "kit" it might still blow in a few years down the road.
Well why not just use some AVIATION GRADE PERMATEX on the damn plenum and call it the day ?
Woooooooooo Aviation Grade........yeah, right. Do you know what aviation grade means? Usually that the US Government pays 5 times as much for a product. Doesnt mean its better. And copper RTV? Come on now....If I was going to try to throw some crap on there to make it stick I would look at metal set. Or just common off the shelf JB Weld. Aviation grade dont mean crap. The reason I know this is I work on aircraft every single day.
Old Feb 23, 2009 | 08:35 AM
ophidia's Avatar
ophidia
http://www.permatex.com/products/Aut...sket_Maker.htm
It's just an RTV sealant that's more oil resistant than regular RTV. Try sealing up your plenum pan with JB Weld and I can guarantee that it will crack and leak almost immediately.
Old Feb 23, 2009 | 05:51 PM
Jpnorris87's Avatar
Jpnorris87
Yeah, JB weld prolly would crack. All I was saying that im damn sure not going to use some big fancy "aviation grade" RTV on to try to fix it. Its retarded. Honestly, if my plenum ever goes out, Im just goin to have sheet metal make me a plate out of "aviation grade" aluminum and call it a day.
Old Feb 23, 2009 | 07:30 PM
burnnxs's Avatar
burnnxs
Originally Posted by BlueBeast2
eh noobs
Do you even know what Aviation grade permatex is?
How you ever used it before ?
I don't think you know what you are talking about OL MIGHTY SUPER POST ***** bluebeast because that stuff is simply amazing to seal stuff you don't need to mess with very often. it is something similar to TAR to my eyes.
Let's do this... I seal my plenum with the "E NOOB guimic" and report back in one year to see if it is blown ?
BTW
bluebeast great sentence structure, with post like that your 9## + posts are probably not longer together than a couple of paragraphs.
Old Feb 23, 2009 | 07:34 PM
PurplDodge's Avatar
PurplDodge
Stupid noobs.
Old Feb 23, 2009 | 07:43 PM
burnnxs's Avatar
burnnxs
Hey don't look at me as the retard, Im under cars everyday without a nanny ,hand book & check list to earn a living un like you.
I can care less about the name... hell name it whatever you want but I would of name it "TAR for douche bags that work on airplanes ".
with that taking care off ^
Look all im saying is this, that stuff is great and stands the test of time if you don't believe me pick one up wherever you like and try it on something then put some heat to it and see wht happens. it's not a paste/gel like compound ( like regular RTV ).
