heater
Old Feb 23, 2009 | 11:31 PM
specialpete2004's Avatar
specialpete2004
Default heater
i have to replace the heater core on my 2000 5.9 liter ram 1500. are there any special tools that i need, any special tips on what to do, or problems that i will run into. also, that dash does not rattle now and i dont want it to rattle at all when im done. is there anything i can do to ensure that this does not happen?
any help is appreciated
Old Feb 24, 2009 | 06:33 AM
dblj16380's Avatar
dblj16380
When I did my heater core I just un-bolted the steering column from the dash and laid it on the seat and then un-bolted the dash and pulled it out as much as possible. Then I un-did anything holding the core in (shouldn't be much) and the heater hoses and lifted it right out of the box. Some people say that they had to disconnect their A/C to get it out. I didn't and it worked fine.
Make sure to take your time and look for anything holding it down so that you don't spend time trying to pull something out that is still connected.
Good Luck!
Old Feb 24, 2009 | 06:43 AM
Laramie1997's Avatar
Laramie1997
Be extremely careful with any part of the dash you remove. Treat like an already cracked egg! These dashes are very fragile and are prone to breaking.
Old Feb 24, 2009 | 10:24 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Any special tips? Yes, read the DIY in this forum and study the pictures. Plan on spending about 4 hours dismantling the dash but about 2 hours buttoning everything back together.
