headlight adjustment
Old Feb 24, 2009 | 03:14 PM
junit2111's Avatar
junit2111
Default headlight adjustment
how do u adjust the head lights it a o1 ram 1500 sport i called dodge they want 40 dallors to do it seems like a waist a money for them to do. thanks for the help
Old Feb 24, 2009 | 04:25 PM
TMS Bill's Avatar
TMS Bill
Click here: http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
The procedure starts on page 8L-21.
Old Feb 24, 2009 | 06:02 PM
olyelr's Avatar
olyelr
I didn't check out that link posted above (too lazy to wait and download it), but all you do is turn the screw just below them (between the bumper and the light). It is a torx head screw, but I cant remember what size.
Old Feb 24, 2009 | 07:32 PM
TMS Bill's Avatar
TMS Bill
Since it's an alignment (one that can get you busted if you do it wrong), I figured he'd need the entire procedure.
Old Feb 24, 2009 | 11:30 PM
olyelr's Avatar
olyelr
Yeah, I gotcha. When I adjusted mine all I did was go out to a long flat road at night and start turning the screw until they shined where I wanted
I wouldn't mind reading up on the proper way though. I download that link, but Im too computer stupid to figure out how to open it. Cant you just paste the directions into the post?
Old Feb 24, 2009 | 11:41 PM
TruckinDodge's Avatar
TruckinDodge
I don't know how to attach the file but I used this to adjust my new projector head lights.
VISUAL HEADLIGHT AIMING PROCEDURE
INTRODUCTION: It is of utmost importance that your vehicle's lighting system be aimed properly in order for it to perform its best. Lights that are aimed incorrectly will not only perform poorly but may also offend oncoming traffic. When replacing bulbs, it is a good idea to verify that your lights are properly aimed. Slight variances in filament position can translate to large variances in beam pattern. The following procedure does not require special aiming equipment and ensures proper aim.
STEP 1: Find a flat level surface adjacent to a vertical white wall where the car can be parked (a garage door is an ideal location at home). Pull the car straight up to the wall as close as possible and draw a vertical line on the wall corresponding to the centerline of the vehicle (this can be done most precisely by using a yardstick and extending it from the hood ornament or badge to the wall). Pull the car straight back until the headlights are 25 feet from the wall.
STEP 2: Make the following two measurements:
Measurement A: From the ground to the geometric center of one of the headlight lenses
Measurement B: From one of the low beam headlights to the vehicle centerline. (Also measure from high beam center to vehicle centerline for 4 headlight systems) Note these measurements.
STEP3:
(A) Two Headlamp Systems:
Draw one horizontal line on the wall at a height exactly 2 inches lower than Measurement A made in Step 2. On the line, make vertical marks both to the right and left of the vehicle centerline mark at the distance of Measurement B from the vehicle centerline vertical line.
(B) Four Headlamp Systems:
Draw two horizontal lines on the wall, one at the height measured from the ground to center of the headlight and one at a height exactly 2 inches lower than the measurement from the ground to the geometric center of the headlight made in Step 2. Make vertical marks for the low beam on the lower line and vertical marks on the upper line for the high beam as in Part (A) above (the high beam marks are made at a distance corresponding to the high beam measurement made in Step 2).
STEP4:
Turn the headlights on and adjust the vertical aim of the headlights so that the top horizontal cutoff of each of the beams is located along the horizontal line drawn on the wall. Adjust the horizontal aim of the low beam headlights so that the point at which the top cutoff of the beam begins to slope upwards is located at the vertical marks made in Step 3 (A).
Adjust the low beams as in (A) above. Adjust the high beams so that the center of the illuminated region is located at the cross formed by the upper horizontal line and the vertical marks made in Step 3 (B) above.
Old Feb 25, 2009 | 12:43 AM
TMS Bill's Avatar
TMS Bill
Can you open a zip file? If not, get WinZip or 7zip (I use 7zip) to extract it. There's a pdf file in there, readable with either Adobe or Foxit Reader (I prefer Foxit). I like the procedure in the FSM `cause there's pictures.
