Water in system
Old Mar 9, 2009 | 07:17 PM
  #51
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by TMS Bill
What's the difference between American trucks and those of Europe?
Besides looking different? They are not American made gas guzzling P's OS ! LOL Which is why they are hurting.
Old Mar 9, 2009 | 07:41 PM
  #52
TMS Bill's Avatar
TMS Bill
Not sure I consider a Range Rover or a Land Rover a truck. I have seen an English sitcom in which one of the characters drives a Toyota pickup ... not really European, though.
Old Mar 9, 2009 | 08:07 PM
  #53
aim4squirrels's Avatar
aim4squirrels
Ok ... um ... don't demean your truck by calling it a car. You sound like you're from New England or something ...
No that'd be a caaa
Old Mar 9, 2009 | 09:52 PM
  #54
TMS Bill's Avatar
TMS Bill
You're right, of course. I should know this ... I'm a Masshole myself. I was just poking z ... no bite.
Old Mar 9, 2009 | 10:30 PM
  #55
aim4squirrels
that's funny so is my wife. Lexington to be exact.
Old Mar 9, 2009 | 11:22 PM
  #56
TMS Bill's Avatar
TMS Bill
Small world, I'm from the Cape (she'll know what that means) ... Buzzards Bay ... ok, so TECHNICALLY not the Cape ... but just across the bridge.
Old Mar 10, 2009 | 10:31 AM
  #57
Pysiek's Avatar
Pysiek
I'm from Poland. The difference between European truck and American trucks is the power,size of the engine and of course American truck are sexxxy :-)
Old Mar 10, 2009 | 11:41 AM
  #58
dodge15004x45.9's Avatar
dodge15004x45.9
Unhappy
Originally Posted by Mowhawk
I had that same sucking sound for a little while too. Turned out to be a small crack in my rad. Then i noticed that i was constantly loosing coolant, but not at an alarming rate. Put in some stop leak and problem was fixed. Have since replaced the Rad. though. Maybe you have a small leak somewhere?
Should have put an egg in it lol.
Old Mar 11, 2009 | 06:33 AM
  #59
rdhd's Avatar
rdhd
There are two ways to solve this.
If you have the T-stat out, fill the block through this opening as well as the rad through the rad cap. Install the T-stat, housing and hose but leave the rad cap off. Start the engine and let it come up to to temperature (180'-192') the water pump will circulate the coolant between the rad and block. Add coolant as necessary to keep the rad full, this may take some time. You may have to squeeze the upper rad hose to remove any air pockets, you may notice some bubbles.
The second method is open the rad cap, fill the rad and start the motor. As the coolant level in the rad drops, keep filling it. Make certain the engine temp gets hot enough to open the T-stat (180'-192'), squeeze the upper rad hose to remove excess air as above.
In both ways above, after the engines are up to temp and the rads are full with no air in them,install the rad cap and fill the overflow bottle to the correct hot level.
Cheers!
Old Mar 11, 2009 | 10:46 AM
  #60
Pysiek's Avatar
Pysiek
Talking
Thanks rdhd . But the problem is solved already
